Page 4 of 4 FirstFirst 1234
Results 61 to 76 of 76
    #61
    How about under your seat? Will it not fit? I have seen some located inside the trunk on top of the subwoofer or besides it.
    A small amp will fit under the seat but powerful ones will be too big, plus you have to consider the wiring. I would not suggest putting the amp into the sub box.
    Dec 2017
    #62
    That means, those who installed it that way are not experts.
    #63
    You can build a box attached to the amp rack but you do not bolt on the amp on the sub enclosure. You don’t want unnecessary vibrations from the enclosure to rattle your amp.
    #64
    May air vent kasi under the seat. Or probably fabricate na lang ng raised platform. Tingnan ko pa ng maigi.
    Sa trunk di ko pa naiisip masyado. Ineexplore ko pa kung i mount sa likod ng rear seat pero mukhang complicated kung kailangan ko itumba yung upuan.
    Dec 2017
    #65
    Quote Originally Posted by robot.sonic View Post
    I also looked at the possibility of installing it on the rear seats but then there are times that I need to fold it and use the whole space.
    Since the CR-V 98 has plenty of space in-between the driver and passenger seats, I contemplated on putting it there.
    I ended up installing it under the driver's seat and it barely fits.
    #66
    Any feedback sa DLS RA50? Yung other choice ko ay yung DLS A7 kung for sale pa kaso 8 years old na.
    Yung RA50 ay brand new. Parehong tag 15K.
    Infinity Reference 4555a - 14,100 lang.
    #67
    15k for a new RA50? Kunin mo na yan, bro! Very capable yung mga classic DLS amps. Kahit nga yung CA51, maganda na. Eh mid-tier yung RA50 tapos ultimate series yung A7.
    #68
    Hmmmm….. di kaya mali ang pricing sa mickey?
    matawagan nga.
    UPDATE: wala na daw silang ganon. huhuhu. paasa.
    #69
    matawagan nga.
    Baka pre-owned yan. Yung CA51 nga nasa lampas 20k yung bago nun even mga 10 years ago. Nasa lampas 50k yung A7 eh.
    Kung gusto mo maliit na space for amp, puwede ka gumamit ng Class D amps. Mas malakas output ng Class D and smaller yung frame nila compared sa Class A/B.
    #70
    pag wala na talaga akong mahanap na matino mag brand new pioneer na lang ako na 5 channel. pwede pa installment sa blade.
    isipin ko pa ulit yung A7. kinakabahan kasi ako doon baka fake e. pero mukha naming enthusiast yung seller. kaya ba hinde fake. mga 2 weeks ago 25K presyo nya. then after a week siguro naging 20K. then 15K.
    #71
    Baka kelangan nya pera for other toys. Maganda sa maganda yung A7 pero kung mababa na demand sa used market, bagsak presyo nyan. Parang Accord, kahit anong ganda nya pa pero kapag bentahan na used, mababa na kasi iilan lang bumibili ng used midsize cars.
    #72
    Tama ka sir. Kausapin ko na ulit yung seller.
    may idea na din ako kung paano ko imount yung amp. sa trunk na lang. floor level. tapos gawan ko ng raised platform kung saan ko pwede ipatong yung sub. may konting headroom lang sa amp para sa ventilation.
    as soon as makakuha ako ng amp, proceed na ako sa install.
    may gumagawa ng mga sub box na taga baguio. from the fb posts mukhang nasa level ni simplesound yung gawa pero half the price.
    #73
    Mukhang pwede ang gladen rc 150c5 amp. 22k sa mickeys. wala pa masyadong review sa net.
    RC 150c5
    5 channel Amplifier Class-AB (channel 1-4) + Class-D (channel 5)
    High Level Input with Auto Sense (no Remote required)
    Optional Remote-Control Module
    Power in RMS:
    * 4 Ohm: 4x 90 Watt
    (channel 1-4)
    * 4 Ohm mono: 1x 360 Watt
    * 2 Ohm mono: 1x 560 Watt
    (channel 5)
    nalilito lang ako sa gladen and mosconi. pareho lang ba ito?
    #74
    Ask Mickey if you can run full active with that amp without the need of a processor or external crossover. It would be bang for the buck if your amp has those features built-in.
    #75
    tinanong ko na sir egan. sana mag reply kaagad. di pa ba enough yung capability ng 80prs HU sir? may mga crossover settings naman sya.
    HPF sa tweeter
    HPF and LPF sa woofer
    LPH sa sub.
    #76
    Pwede daw pang full active yung amp kasi capable naman yung HU ko.
CRV SQ Setup
