Quote Originally Posted by pbcnx View Post
So eto na po yung magiging connection ng setup ko po?
I found the brand of the sub na bibilhin ko, it's an audiobahn 2 pcs 12" sub with a bandpass enclosure. sounds good naman IMHO.
These are bridgable right?
You are all set and ready to fire up. Your 2 channel amp gives you two output but that doesnt mean you have to connect two subwoofers. You can connect 1, 2 or even 4, you just need to be aware of the impedance and the load capability of your amp. So look at your amp if stable down to 2 ohms. Now, when it say's 2 ohms stable on your amp it referring only to the minimum impedance it can handle in 2 channel mode(not bridged) but mono. I believe your subs wired in parallel, if it is, your impedance are low meaning your 2 ohms amp will give you more power because less resistance or load to the amp. The more power it produces, the louder the music play's.
If you want to tune your system, I can help you. Whenever you are ready PM me.
