Most car audio head units have a 50Wx4 MOSFET built-in amplifier. It's mostly 23W RMS * 4ohms under 1% distortion. Get anything more and your distortion plot will rise dramatically until it's around 20% at 50W. Another thing people should know is that head units are actually 8 channels that are bridged in order to get 23W on all four channels at 4 ohms. This is the reason why you can't bridge the outputs to get something like 2x50W RMS.
But that's simply a tidbit on my parttotally unrelated dito haha..
Well, if it's the entire speaker box as you outlined above..
Pwede. No problems there. Parallel connection of 2 speaker compo systems on each channel.
Problem here is that speaker compo systems aren't really subwoofers. They're just tweeter + (midrange) + midbass in a plastic ported enclosure. When it comes down to it, they won't hit 30hz and that's considering a natural no-crossover slope. A single 10" subwoofer will be more efficient than all 4 6" midbass drivers in reproducing bassy sounds.
Also, I'm not too sure in wanting to have component systems under your seats. Thanks to the higher frequencies, your ears will automatically locate in your head that your music will be coming under your seat -- in other words, you'll hear music playing below your ass.
If you want the bass of the midbass drivers in DIY setup. You can always yank them out, try to get a crossover that covers dunno... 63/80hz to 300hz, fabricate a slim-type enclosure for use under your seat.. and voila.. DIY under-your-seat midwoofers. Still, for the cost.. a powered subwoofer might be a more ideal setup.
Still, kung gusto mo talaga ng bass, there's nothing more ideal than getting a 12" GT5-12 subwoofer (3,000), a ported enclosure (cost depends on installer), some wires, and wire it to an affordable V12 amplifier when you're talking about costs. You can also use 12" Targa drivers to further reduce cost if you'd like.
Since ilalagay naman niya sa likod ng Revo.. I'll probably get the entire compo set, throw it at the back, get a power inverter.. ayun na yun.. DIY loud and clear vehicle. This is probably the easiest solution if you want a compo set inside a car.
