Results 1 to 16 of 16
    Aug 2003
    may pinuntahan ako car audio shop sabi nya hanap lang ako ng cable ng cd changer tapos sya na daw bahala magpapalit ng input rca nya...
    pwede ba yon?
    ang mahal kasi ng cd rb10 1.8k to 2k
    basta hanapin ko lang daw yung color blue dito sa picture...
    same din daw ito sa mga cd changers ng pioneer...
    may nakagawa na po ba nito? DIY? any diagram...tnx
    Aug 2004
    research ka sa net! hehe
    Aug 2003
    been there done that
    that is why I am askin, boy
    I haven't done that pero palagay ko cable lang nga yun. What he needs it the adaptor (blue) to fit your HU. Do you still have the schematic diagram ng HU mo?
    this might solve your problem dude:
    and here is the web page
    http://users.tpg.com.au/johnkg/skyli...eer/index.html
    Aug 2003
    YEHEY!!!
    [SIZE=7] Perfect!!![/SIZE]
    thank you sooooooo much!!!
    Aug 2003
    Sir wildthing just a follow up question for the RCA jack..
    which is negative and positve for the rca jack?
    inside ba negative and outside metal is positive?
    tama po sir or baligtad?
    THANK YOU VERY MUCH!!!
    baligtad. Ground ang outside..normally kung ano ung prone maexpose sa labas ay ground...pinoprotektohan ung positive kaya nasa loob. To be doubly sure, also try asking the electronic store where you plan to buy your rca jack/plugs about the right polarity ng RCA.
    Aug 2003
    oh ic thank you very much sir
    hunting muna ako ng ip bus connector tom monday... ;)
    kung wala kang makuha, I would suggest DIYing a plug that would be directly plug into the back of the HU. Some electronic stores (like Alexan or Deeco) might have a "pole" plug (gawa ito sa copper) that might fit the prongs in the back of your HU. Then para hindi ito mag ground sa nearby prongs you can cover it with a "spaghetti" protector or a "shrink-wrap" wire protector (electronic store might also have these- yun shrink wrap naman uso sa R/C hobbyist stores). Goodluck sa project mo.
    Sep 2004
    Paano kapag may nakasaksak na CD changer na dun sa IP?
    then perhaps you don't need this device?!?
    Sep 2004
    Quote Originally Posted by wildthing
    Is there a way to use my CD changer and still be able to plug-in an IPOD? Paano po ba mag-connect 2 sources sa IP?
    Sep 2004
    Quote Originally Posted by albert_b
    Hehe nakita ko na sagot sa tanong ... the Pioneer RB20
    Mar 2003
    possible ba mabili yung ulo cd shuttle wire lang? how much kaya ito? medyo nakakatakot mag solder kasi.
    May 2005
    tama si wildthing, yun outer ng rca is the ground(-) and the inner is the positive(+).
    one question lang jeepcruizerph, does your pioneer headunit have the AUX function?
    kung wala siya, useless lang ang cd rb10. cdrb10 gagana lang sa mga HU na may AUX function.
CD RB10 DiY anyone ?         (pic)
