Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    good day everyone, just wondering ilan kailangan na rate ng alternator if im putting in HID(siguro 6000k), SPL sound system (2 amp na jbl then 12" subs, seps, and crossover)
    im plannig to put it sana pero takot ako baka hindi kayanin ng alternator ko. currently, i have a 1 amp sound setup and H4 narva super white 100/120 ata. kaya naman ng alternator ko but if i was to do the above metioned anong rating kailangan ko para hindi mabitin sa power.
    magkano kaya abutin ng higher rated na alternator?
    thanks sa magreply.
    Why 2 amps for 1 sub and seps?
    Personally I don't think you'd need to change alternator for that (depends on your car though). Mababa rin ang power rating ng standard HID's diyan compared sa super white na gamit mo ngayon.
    Kung takot kang madiskarga, it would be best to buy a secondary battery instead kaysa palit ng alternator.
    thanks for the input batang raon
    baka confusing pagpost ko... my current setup is 1 amp lang, so kaya ng alternator. ang plan ko is to upgrade my sound system to a 2 amp setup (SPL) + HID 6000k. takot lang ako na hindi kayanin ng alternator yung plan ko na setup... so kaya ng alternator basta may isa pang batt? thats good to know
    Mar 2005
    Planning on using 1 amp for your sub and 1 for your seps?
    Anyway, I don't think you would need another battery. I've seen setups with 3 amps on 1 battery. Also, most HID's are rated at 35w so it uses less power than ordinary headlights (usually at 60w). If there are signs na kulang ang charge (radio turns off when you turn headlights on, step on the brake etc) have your alternator checked with your suking electrician. Baka maluwag yung belt or kailangan na magpalit ng carbon brush. Pero kung di naman, mag capacitor ka na lang.
    I have a fairly decent setup wired 1 amp sa subs and another amp sa 2 sets of seps 75x4 lots of little things like neon and strobes sa trunk, upgrade halogen lamp, and decent two tone horn additional cabin lights (maplight)
    Upgrade lang ako sa battery and installed kinetik power cell as backup sa likod.. kayang kaya lahat ng load I tried cranking up my setup with all efects on di naman nag drop below 12V engine off after 20mins of playing, even the bass is thumping I observe the voltage stable naman...
    I saw one serious SPL setup sa Fortuner additional backup battery lang din ang nilalagay nila.
    should be ok...i have run 1000w amps on stock Toyota alternators before...
    Install all your gear and see first if you have problems .
    Just make sure you use proper gauge wiring for all the power and grounds and that you do the BIG3 in the engine bay to maximize your current electricals .
    (for all you know, you'll be fine and wouldn't have to spend anything extra )
    paps try mp upgrade wiring yung tinatawag namin sa kotseadioclub.com na
    big 3 1.positive batt to positive alt 2.ground to engine 3.engine to chassis try mo muna to dami na ganto situation sa KAC na ganto lang ginawa solve na problem nila even me i used it,no need to add batt or chance alt much more cheaper pa,then if u have extra budget capacitor will also good for your system....hope this help
    hindi ko na tinuloy project ko for the spl set up--- ang mahal pala to upgrade. salamat po sa mga reply niyo, papagawa ko na lang yung big 3 na sinasabi nila...
    sir... pinagawa niyo ba yung big 3 upgrade or DIY lang? hindi kasi ako magaling sa mga DIY and ayw ko magrisk.
    any electrical shops ba kaya to?
    magpapagawa na kasi ako ng oto by mid march para isang buga na lang gastos (ouch!). medyo busy pa kasi ngayon.
    thanks po ulit..
    Mar 2005
    Madali lang po yung big 3. You just need some big wires. It will cost you less than 100 pesos. Pero you can also get a grounding kit from car shops and have it installed. Sabihin mo lang yung isang wire from BATT + to ALT +. Most car accesories shops know this naman e. Siguro it will cost you 800 pesos.
    ahh ok thats good kung mga 8oo lang gagastosin ko for the whole thing. plan ko po sana na this midmarch ako pagawa pero nabanga naman ako kaya nasa casa car ko. hayyy, i thought na yung may free time ako by midmarch kaya na pagawa... yun pala mababanga ka lang. hassel.... have to wait until june na ulit.
    anyways, thanks po ulit sa mga reply niyong lahat.
    Archie - do you have a Capacitor for your subs?
    Nov 2007
    Quote Originally Posted by irvhine View Post
    What size of wire did you used in bat + to alt +? i checked the connection of may alt and i saw not so big wire. parang kasing laki lang ng standard automotive wire.
    question after you made this big 3 did you noticed improvement? plan ko gawin ito kasi as of now ground to engine lang ang inilagay ko wala pa yung big 2. TIA
    wala po ako capacitor for my sounds... sobrang basic lang. kung baga, budget meals lang. hehehe...
    v12 amp
    a/d/s tweeter
    audio bank mid
    pioneer 4 way 6x9
    12" pg subs (sealed)
    kailangan ko po ba nga capacitor for this setup? or ground kit/ big 3 lang?
    Jun 2006
    IMHO, your stock electrical system can definitely supply your current system. Of course, if you want to upgrade it with capacitors or the Big Three, that's perfectly ok. I suggest jumping to the Big Three instead, ground wires can only offer so much improvements.
    I did the Big 3 last Holy Week, and improvements were noticeable.
    Jun 2007
    magkaiba ba ang big 3 at grounding kit upgrade? naka ground kit ako ngayon sa sound setup ko medyo nagflicker parin yung light pag nagboom, ok kaya mag big 3 nalang ako? o pwede sabay dalawa? thanks
    Nov 2004
    from what i've been reading here, ground kits are connected from the negative pole of the battery, on the other hand, "the big three" is from the positive pole.
    look here: http://tsikot.yehey.com/forums/showt...t=15402&page=2
    may photo sa may middle ng page, pinagsabay niya yung grounding kit and big 3.
    tama ba ito? thanks.. i need to be enlightened.
    May 2007
    Quote Originally Posted by archie123456789 View Post
    thanks sa magreply.
    Go ahead....load it up, walang problema diyan. But, if you go higher or add more AUDIO BLING BLING need to upgrade your Alt. should I say, 95 ampere.
    Jul 2006
    You can complete the package and go with an Optima Deep Cycle battery (yellow top) for all your electronic needs.
    Aug 2006
    Quote Originally Posted by v6dreamer View Post
    X2
    anong ride ba???
cars with big load of electronics
