Results 11 to 20 of 21
- 24
- 36
November 22nd, 2002 01:21 AM #12Originally Posted by ice27
2 15" Sub? nagkasya sa trunk mo with box? or free-air ang setup mo?
- 31
- 24
November 22nd, 2002 09:06 PM #14silver,
Iam going to fit the two speaker to my ford lynx ghia. The question is, is there a possibility na mabasag yong salamin if ever gumana sya????or i need to open the window every time tutugtog??????tnx.....
November 27th, 2002 09:11 PM #16
san shop magandang bumili at magpakabit ng car sound set-up sa pque, makati pasay area?
November 28th, 2002 11:57 AM #17
boyscout,
sa may mayapis sa likod ng pamantasan ng makati dame duon nag set-up duon. after golden bridge car accessories mukhang ok gumawa... tanong kanalang duon kase tabe-tabe sila.
- 3
November 28th, 2002 06:11 PM #18pag sinabing 2 ohms load. Mas malakas ba pag ginawang 2ohms ang subs kaysa sa 4 ohms???
- 36
December 2nd, 2002 06:28 PM #19Originally Posted by asar
I think it depends on how you set-up... but the lesser ohm will have bigger output (watts) but if you have a dual voice coil with 2 ohm on each coil, mahihirapan yung amp mo since pag nagparallel set-up ka magiging 1ohm load ka na! pero pag paraller dual 4 ohm, magiging 2 ohm siya & it will doble your power (watts)
that's what i know but correct me if i'm wrong, tama ba audio gurus?
- 24
December 17th, 2002 02:27 AM #20Mga bossing tanong ko lang ulit may cd changer ako sa likod di kaya tatalon yong tugtug pag bumayo yong sub?
high idle RPM at engine start
