Results 31 to 40 of 91
September 18th, 2007 07:41 PM #31
input power equals output power plus power losses of the adaptor. minimal lang naman ang losses ng adpator so negligible so puede mo ng computin ang watts used by the laptop sa output ng adaptor..
DIY to death!
- Jan 2003
- 451
September 19th, 2007 12:51 AM #32Ingat kayo sa pagbili ng mga inverters na yan. Dati bumili kami sa DIY Gateway, binalik ko lang. Its actual output was in excess of 500 volts, so siguradong tostado mga isasaksak ko dun. We brought a voltmeter when we returned it para makita nila talaga. They offered to replace it, kaso lahat ganun. Sorry, I forgot what brand it was, but its form factor is similar to the pic above.
BANNED BANNED BANNED
- 3,790
September 19th, 2007 08:33 AM #33your idea is indeed very logical. Ang normal household appliance is barely less than 100watts lang nga.
ang pinagtataka ko lang kasi I have 2 inverters - both are rated 300watts. My older unit got busted but a close friend of mine managed to repair it. After that repair working siya sa Toshiba Libretto charger ko. Then when I shifted to a Neo Laptop charger hindi na nito kinaya. Lagi itong nag - "ooverload". Pero sa cellphone charger walang problem ito.
Napilitan tuloy akong bumili sa Alexan ng 300watt inverter nila. This one worked very well with the Neo charger.
So I deduced that I would need a 300watt inverter for laptops and nothing less.
- 3,790
September 19th, 2007 08:37 AM #34Pero kung gagana yung cute na inverter na pinost ni Boybi sa laptop niya, i would want to buy one too.
Boybi, pagnatuloy kang bumili, tell us your opinion on that.
September 19th, 2007 08:46 AM #35
may inverter sa CDR king rated at 250watts at 700 pesos, its the small amplifier looking thing.
- 3,790
- Aug 2007
- 675
September 20th, 2007 11:57 PM #37Nakahanap ako dun sa mga car shops in SM, yung red yung color ng shop nila. Its mga P800 yung 80 watts then they had one na P1000+ higher wattage (mga 250 watts siguro)
September 21st, 2007 12:22 AM #38
- Aug 2007
- 675
September 21st, 2007 02:06 AM #39
September 22nd, 2007 10:21 AM #40
Mura CDR-King. Less than 1000 price. Oks sya at eto gamit ko ngaun, nakakayanan namang icharge ung laptop ko and so far oks ang takbo. Dalawang saksakan pa pwede saksakan (pero normally pag parehong phone chargers lang, kasi pag laptop ung isa sabay laptop din ung isa pa, alanganin, 150watts lang kasi).
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
