Results 1 to 10 of 44
April 5th, 2011 10:59 PM #1
I need advice where in Metro Manila I can have Big 3 upgrade.
Here is what I am putting into my SUV.
Pioneer GM-D8500M (300w RMS at 4 ohms)to power Kicker 10CVT124 (400w RMS * 4 ohms)
Bazooka MGA4150 (100w RMS x 4 x 4 ohms) to power 4 Infinity Kappa 63.91 - (75w RMS)
I have 6 (35 watt) HID installed on my SUV.
April 6th, 2011 09:38 AM #2
April 7th, 2011 03:26 AM #4
Please PM me a estimate. I would also like to include a fuse between the alternator and the battery for extra protection. 2011 Montero Sport.
April 14th, 2011 02:07 AM #5
Weird, I think di mo pa kilangan ng Big 3 upgrade then. Most people usually do it once they start seeing dimming headlights at idle.
April 14th, 2011 10:35 AM #6
He just want to maximize the power requirements for the whole accessories sir, i think for future purposes kaya nya kelangan big three upgrade, for the full performance, he don't want to wait goes headlight dimming before he act to do something, big three upgrade eliminate tension in the wires and provide less corrosion to the terminals, if you notice the original wires, its only for the installed accessories, so if you add something there, the tension on wires is present, big three is better than grounding kit, big three is better than adding additional battery or another power supply and also big three can also maximize the current cycle to the whole circuit without the tension or great resistance..
- Dec 2008
- 50
April 14th, 2011 06:07 PM #7gusto ko i-diy itong big 3. ok na ba yung gauge 4 wire and gamitin? dun lang ako sa +bat to +alt nag-aalangan. alin ba dito yung + post ng alt.... A or B?
*tsikotshop - pre, pa pm naman nung price mo para + alt to + bat connection. yung sa dalawang connection kaya ko na yun. thanks
April 14th, 2011 10:43 PM #8
*tsikotshop
I see, newbie palang ako sa mga electrical systems ng kotse ehmaybe I should add it in my to-do-lists in the future.
April 15th, 2011 01:47 AM #9
April 15th, 2011 01:57 PM #10
Big three will be enough sir, thats the only thing you do for your system, capacitor will do little help,
, but get a real one for these, the function of the capacitor is to pick huge current that cannot carry by your battery, and firstly force the current to the accessories that requires more power, so your battery will last longer, dapat dito, sigurado wiring mo, kase di po pwede lagyan ng fuse ito, magiging useless.
The Yokohama BluEarths notoriously break down as you use them. I guess something in their...
Finding the Best Tire for You
