Results 1 to 8 of 8
- Feb 2008
- 12
March 4th, 2008 06:08 PM #1meron ba effect sa sound? need suggestion po sa setup ko
HU - Sony xplod
Pioneer eq booster
2 6" stock techline front speakers
2 8" targa subs
yung sasakyan ko ay suzuki APV po
ano po ma e suggest nyo? ok lang sa akin na hindi msyadong gapang bsta ok lang yung sounds ko.
March 4th, 2008 06:39 PM #2
Yes and no.
Yes kung maliit ang mgs wires mo, less than 16 or 14 AWG.
No kung naka 0 AWG ka then gagamit ka ng 00AWG or bigger, kasi almost no effect na sa pag baba ng resistance ng wires sa audio system.
This is one of those diminishing returns. habang palaki ng palaki ang wires, pababa ng pababa ang magiging effect sa power hungry audio system.
The trick is to find the optimal wire size and this will depend on how long the wires will run. Longger runs needs bigger wires. shorter, smaller diameter wires.
Tsikot Member Rank 4
- Jun 2006
- 2,605
March 4th, 2008 09:56 PM #3Correct si Meledson.
May amp ka ba? For amp power and ground cable, use the thickest you can afford. But 8 guage is enough. For speaker wires 12 guage should be good enough.
- Feb 2008
- 12
March 4th, 2008 11:36 PM #4ah ok.. meron akong amp 4 channel cya sa setup ko sa itaas need ko pa ba xtra sub speakers?? ok lang ba kung HU>Amp then connect ko yung front at subs ko sa amp na? how about sa output ng HU ko ano e connect ko?? patulong sana ako ng basic setup lang for beginners na katulad ko..
- Jun 2006
- 2,605
March 5th, 2008 12:17 AM #5ok na yan. front seps and subs sa amp. kung may rear speakers ka, pwede mo na connect sa HU or wag mo nang gamitin.
Sound should come from the front. just like when you are in a concert, the performers are infront of you. Some hi end systems dontr even have rear speakers. Rear speakers if used should be to fill. Thats why its called rear fill. Personally, for big cars like SUVs and vans, I like to have rear fill powered off the HU or a small amp. Just to give passengers something. For cars, I dont bother with rear fill or I fade it so I hardly know its there.
March 5th, 2008 12:24 AM #6
sir metanoya, pa share naman ng simple mods nyo sa club namin na suzuki owners (APV and carry) sa www.clubcarryph.tk also interested in your project. nga pala, bakit ka pala nagpalagay ng additional speakers sa harap kung ok naman ang mga stock speakers natin?
- Feb 2008
- 12
March 5th, 2008 01:22 AM #7nka register na po ako dun . im not sure if ok pa ba yung stock speakers ko if ilalagay ko na yung amp ko ang ginamit ko pa kasi ngayon is Eq booster so ok pa cya pero pag mataas na yung vol ng HU ko basag na yung sound lalo na kung bumabayo.. Pde po ba magamit ang Equalizer ko kung maglagay na ako ng amp? kasi mganda rin kasi yung tono ng Eq gsto ko lang magdagdag ng bayo sa sounds ko.. thanks po sa mga nag reply
March 31st, 2008 08:12 PM #8
high idle RPM at engine start
