Results 1 to 10 of 10
April 21st, 2010 09:05 AM #1
Nag-upgrade ako ng HU ko. Pinakabit ko dito sa Cavite. Pero nagulat ako nawala yung bass. Nung una kala ko baka sa timpla lang pero hindi pala. Napansin ko lang pag nakabalance yung speakers eh wala siyang bass pero pag nilagay ko sa left lang yung balance or sa right speaker lang bumabalik yung bass. Di masolve nung pinagpakabitan ko eh. Ano kaya problema nito? Thanks in advance
April 21st, 2010 05:46 PM #4
^Good idea kaya lang free installation daw yun eh sabi nung may ari. dammit!
April 23rd, 2010 08:39 AM #8
Problem solved.
Kung di pa ako nagresearch at sinabi sa gumagawa na POLARITY ang problema, di pa nila malalaman. tsk tsk tsk!
April 23rd, 2010 11:25 AM #9
Check the wiring installation on the speakers. As i post earlier.
buti naman naayos na problema mo.
- Mar 2009
- 376
May 26th, 2010 10:19 PM #10Sa mga nakakabasa nito who has the same problem... tama yung naka-post sa taas about polarity. This means isang speaker either left or right ay naka-reverse polarity or "out-of-phase" (meaning yung + and - leads naka-reverse ang connection with the amp / HU), but not both (in which case tutunog pa rin naman). Out-of-phase sounds on L/R channels, lalo na kasi magkatapat ang left and right speakers sa car, would cancel each other out, particularly yung sounds na naka stereo center (i.e. reproduced by both L and R channels), kaya lalong mukhang "walang bass" (normally bass is on stereo center of recordings).
Ayun po ang reason, in case nagtataka kayo. :D
Pero at least solved naman na yung problem nung nag-post ng thread.
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
