Results 1 to 12 of 12
    Jan 2009
    Such as this:
    or this:
    [img]http://ecx.images-amazon.com/images/I/41tm***Ap9L.jpg[/img]
    Please point me in the right direction.
    Thanks!
    Jul 2013
    Curios lang. Anung advantage sa ordinary RCA cable?
    Jan 2009
    Quote Originally Posted by Lew_Alcindor View Post
    Ground Loop Isolators
    *oj
    are you having noise?
    *oj
    Jan 2009
    Quote Originally Posted by benchman View Post
    *oj
    *oj
    Yeah, from the sub preouts to the powered sub. Vehicle noises, like computer buzzing, a bit of whining and pops when electrical loads in the car are turned on or off. Noises stop whenever I disconnect the preouts from the amp, so it's not the amp. No noises as well from the main speakers.
    Checked all grounds and they're fine. I did found out that the amp RCA inputs have floating ground but not on the HU, so on the HU, the chassis ground and the preout/signal ground are common. So i've reason to beleive that there exists a ground loop.
    aside from poor grounding system, check your RCA cables. never run/route your RCA along with any power cables. say if you have the RCAs laying on the left side of your car, run your power cable on the right then.
    also check for stripped RCA insulators or there could be jammed/pinned RCA cable somewhere.
    Problem may be solved by wiring another ground line direct from battery, hu power supply, shielded cables up to the last audio accessory. This works for me everytime i encounter noise.
    -how did you check the grounding? you can use a dvm(with fresh 9v batter) and all ground points should be 0.2 ohm
    -the computer buzz/hum is the sound of coil whine in some motherboards or power supplies or videocards.
    Jan 2009
    Or in my case, power supply or the vehicle ECM/ECU/PCM computer whine.
    I really don't want to tear down the cables again and/or spend a fortune on expensive cables and grounding kits. I did mention that this just happens on the sub-woofer. I think that a ground loop isolator, even though it might just be a band-aid solution, should be enough. This, again is just covering the sub-frequency band, inserting a filter shouldn't cause it to lose perceptible sonic performance.
    Jan 2008
    Lipat mo yung ground ng sub amp mo. Use short cable. Loose grounding lang yan
    Jan 2009
    Ganito na ito before, even in my Civic. But during that time, the sub was in the trunk kaya hindi apparent yung noise. But it is now installed in an MPV so all nuisances and noise can be heard in the cabin.
    Anyway, this issue is closed for now. I've already ordered online.
    deleted post.
    Last edited by benchman; September 13th, 2015 at 01:34 PM. Reason: case closed according to TS
I'm looking for an RCA ground loop isolator locally
