Results 1 to 10 of 22
- Jan 2010
- 31
March 5th, 2010 12:11 PM #1good day mga sir,patulong naman po, hingi lang po advice kung ano 1st step ang gagawin ko for my audio set-up, ang gusto ko SQ lang po.yung medyo cheaper lang yung price pero yung quality ok. yung HU ng adventure di ko na papalitan kasi i think ok na po yun for me.
pwede po ba subs and ampli lang muna ang idagdag ko o i need to change 1st my front & rear speakers?
March 5th, 2010 12:24 PM #2
ano po yung HU ng adventure? baka walang out for the ampli. if there is, start with the inside speakers and to follow na lang yung subs and amp.
paginuna kasi yung subs and amp, baka masapawan lang yung speakers. puro bayo lang maririnig mo. hehe
if i were in your position, ill start with the HU. pioneer 3050 should do the trick, then ipon ulit. tapos 4 ch na amp and seps naman. nakaabang yung 2 ch para sa subs. then kung meron na ulit budget, go for the subs to complete the set up.
March 6th, 2010 06:01 AM #3
Naiopost ko na to sa kabila pero parang mas sakto ang question ko dito:
Sir Adventure ang ride ko. Anong dapat kong bilhin sa Raon kung Targa setup. Budget meal din. Please be specific. V12 amp? Ilang watts? Speakers?
1. First option ko since limited budget. Stock lang muna ang 4 speakers 2 tweeters at Head Unit. So kelangan ko lang ay amp at Targa Speaker 10" for sub-woofer and wires. Anong size ng wire? Anong spec nung 10" Targa? Anong v12 yun basta ba sabihin ko sa Raon isang v12 nga
Sorry newbie sa sound setup. Papatira ko na lang kay Jeff Tan kapag nabili ko ang na piyesa. Magkano kaya ang labor?
Sabi kasi ng friend ko kahit daw stock speaker lang muna mas gaganda na rin daw ang tunog kapag naikasa mo to sa amp. Tama ba? Ok lang di maitodo ang sound basta may boom boom.
March 6th, 2010 06:25 AM #4
not familar with the exact model of v12 amps and targa seps and subs. pero if i were to setup my ride with limited budget, ill first go with the "driver" - the HU. dito magdedepend lahat ng tunog ng setup.
hindi totoo yung rating ng mga v12 kaya mas ok to get 500 watt v12 para sure kayanin yung setup. wattage of sub+seps = amp wattage. dapat higitan yung wattage para busog yung setup.
tama yung friend mo, kahit stock yung speakers, gaganda talaga tunog kung may amp. kasi may built in na crossover sa amp. pero iba pa rin yung talagang seps that produces mid and high range.
as ive said, una lagi HU before anything else. then seps then subs. pero kung boom boom power lang trip kahit wala na masyado marining na mid and high range, mono amp, 12" subs. phoenix gold has a lot of boom boom potential. or kung gusto buoin yung setup -- 4 ch amp tapos buhos muna amp power sa subs then pag may budget na, seps naman.
it will be cheaper to install everything in one go. tiis na lang muna sa stock setup then kung kaya na buo, go na. i assure you mapipikon ka kung boom boom lang maririnig mo.
may mga budget meals si jeff tan, better sa kanya ka kumuha ng lahat para may warranty. kasi kung papakabit mo lang, walang warranty yan kasi hindi galing sa kanya galing gamit.
- Jan 2010
- 31
March 6th, 2010 12:07 PM #5eh sir san po ba yung shop ni jeff tan?
i think yung stock ng adventure glx na HU is meron ng out for ampli..
eh sir archie anong speaker muna ang bibilin ko? wat brand? and wat size? di ko po kasi alam size ng stock speaker ng Adventure glx eh, pero sabi nung nagdedemo ng xplod sa Ace hardware eh 4" daw po yung harap and 5" yung likod..
after po ba nito subs and ampli na next ko?
salamat po, mahirap kasi kung pabarabara yung papalitan ko, baka ako din magsisi sa huli..
thanks!
March 6th, 2010 01:48 PM #6
yung shop niya sa araneta car accessories.
the only way para malaman kung may line out yung HU is to remove it and look at the back kung may butas for the ampli. usually kasi wires lang run sa likod ng stock HU kaya marami nagpapalit muna bago set up.
the speakers will depend on the size of the compartment of the speakers. kung 4" talaga then its 4".
una is the seps and amp. kung all targa setup alam ko may package na 10k kay jeff. mas ok na all in one go kasi kung seps muna, walang bayo, kung subs naman una walang mid and high.
the brand will depend on the budget. for me, ok pa rin lanzar spes. mura na, may bubuga pa.pero sabi naman ng iba, bang for buck talaga yung targa, less than 1k ata meron sila seps, not that sure lang. another brand na ok, ryan audio. try to audition first kung ano trip mo sa ibat ibang brand.
- Jan 2010
- 31
March 6th, 2010 04:01 PM #7
- Mar 2010
- 2
March 6th, 2010 05:15 PM #8HEYI appreciate the concern which is been cars. The things need to be sorted out because it is about the individual but it can be with everyone.
888 casino
March 6th, 2010 06:00 PM #9
ok lang unahin yung seps and amp kaso sobrang matining ng tunog ng oto. it depends on kung lagi ka may sakay sa likod kung lalagyan mo ng seps din yung likod. if not hayaan na lang na stock yung likod para mas tipid.
alam ko yung kay jeff, mga 10k all targa setup. mas ok na ipunin na lang muna para hangang subs pasok. mas magmamahal kasi sa labor kung paunti unti lang kabit. baklas ulit sidings etc.
kung seps and amp lang. palitan yung front speakers ng seps with tweeter, wiring, power supply, and labor. kung pwede paabang lang yung wire para sa subs mas mabuti para hindi na babaklasin yung siding ulit. lagyan na lang ng electrical tape para hindi magsalubong yung positive and negative.
hindi ko lang alam number ni jeff tan.
- Jan 2010
- 31
March 7th, 2010 11:16 AM #10sige sir, ganon na nga lang, ipunin ko na lang muna para sabay2x na yung kabit and labor, atleast nalaman ko na muna yung mga gagawin. thaks sir sa advice.
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
