Page 282 of 307 FirstFirst ... 182232272278279280281282283284285286292 ... LastLast
Results 2,811 to 2,820 of 3070
    Apr 2011
    #2811
    I want to upgrade my civic's (2009 model) speakers. And I want to retain the headunit and just replace the door and rear speakers, are 4 way speakers recommended? And if so what brand to get? Budget speakers only please
    Sent from my SM-A910F using Tapatalk
    Jan 2018
    #2812
    [QUOTE=cmmp;2941952]I want to upgrade my civic's (2009 model) speakers. And I want to retain the headunit and just replace the door and rear speakers, are 4 way speakers recommended? And if so what brand to get? Budget speakers only please
    Sent from my SM-A910F using Tapatalk[/QUOTE
    Jbl or infinity seperates on the front will do of youre in a budget of more or less 3.5k to 5k. Extend it a bit more and get an auditor by focals. For the rear, if you really want to have a rear fill get any of those brand and instead of seperates, get the coaxial variant.
    Mar 2018
    #2813
    For android based hu owners.
    Meron po ba kayong gamit na application as eq? As of current po kase growl audio has only 3. Bass mid and treble.
    Thanks in advance po
    Oct 2008
    #2814
    guys, questions:
    1. ano difference ng "speaker level" vs sa fader settings?
    2. does the speaker level setting affect the time alignment settings? i have the impression kasi dati na ang time alignment, it makes the sound arrive at the same time sa ears natin and I have the impression before na pinapalakas nya yung level ng sound to achieve it.
    Aug 2015
    #2815
    Afaik
    1. Speaker level is the base volume per driver. Fader fades your music to the front, neutral or rear
    2. Your impression is right and it is the fact though speaker level does not affect your time alignment settings it plays a major role in tonality and imaging of your system.
    Quote Originally Posted by artsky View Post
    guys, questions:
    Feb 2017
    #2816
    May kilalaba kayong malupit na audio installer na kayang mapagana yung remote amp ng civic 2017? Yung tamang pag on ng radio, on din yung amp. Ang set up kasi ngayon ay stock h.u. at speakers pero may sub at amp. Yung sub ko at amp may on-off switch para pwede ko patayin ung bass anytime para makapag usap sa kotse.
    Plano ko kasi palitan yung stock speakers sa front at rear at lagyan ng isa pang amp at dun sila ikabit. Bale yung amp ko magiging dalawa, isang sa sub at front at rear speakers. Yung sa front at rear, walang switch remote lang gamit pero yung sub meron. Pwede kaya yun?
    Sent from my SM-T705 using Tapatalk
    #2817
    Quote Originally Posted by zero3 View Post
    front + rear with hi-pass amp - remote powered from HU
    powered sub - manual power switch
    pwedeng-pwede at kayang-kaya iyan kahit hindi malupit na installer. basic lang naman yung remote ON from HU.
    Jun 2016
    #2818
    Im not sure where to post this, so i want first to apologize.
    Possible ba na ma punit yung stock speaker, or even the aftermarket ones, when playing really loud music? T. I. A.
    #2819
    Quote Originally Posted by new_2_cars View Post
    unlikely, but i have seen it happen... in big speakers. not in the small ones used in autos.
    more likely, the speaker is already "previously punited". but that should give itself up as distortion.
    Jun 2016
    #2820
    Thank you sir for the reply. By the way, any recomendations kung anong magandang pamalit for my stock speakers available locally? Something that has a descent sound and bass na plug-n-play. If possible, sana separate yung tweeters. The car is a 2016 Mazda 3.
audio set-up for beginners [continued]
