Page 279 of 307 FirstFirst ... 179229269275276277278279280281282283289 ... LastLast
Results 2,781 to 2,790 of 3070
    Aug 2015
    #2781
    Good day friends.
    So I already sold my 2015 Altis including all SQ equipment installed. I will be getting a Wildtrak and contemplating on the equipment to be installed. I still like how the AP RAM sounds. Jonz suggested the RAM 1.6. Coming from the RAM 2.6 I think this is a good pick as it would also fit well with the Wildtrak's tweeter stock location. Any other alternatives that are comparable or better than the APs for the seps which costs around 20k to 40k? I listen mostly to jazz, pop and a bit of R&Bs.
    Would also like to hear for any suggestions on DSPs for integration. Hard to replace the Wildtrak's HU due to sync3 issues and connectivity with the truck's other systems. I have seen the HELIX P6 dsp + amplifier which costs 60k+. Thinking probably getting a 4ch amp + stand alone dsp but would appreciate other inputs.
    I can go sub less. But Jonz mentioned the Ryan Audio underseat subs. Meron ba sa atin may naka gamit or nakarining na nito?
    Thank you guys
    #2782
    ^ako gamit ko ngayon ryan audio na underseat subs. No complaints naman ako pero hindi ako audiophile kaya baka iba standards natin. What's good for me maybe crap for you [emoji3]
    btw, who's jonz?
    Jan 2018
    #2783
    Quote Originally Posted by Densoy View Post
    Hello po mga Mobile Audio Guru. Ask lang po ako kung ano po ussually cause ng amp auto protect?
    Set-up ko po is DLS P40, 10” Polk MM1 DVC, Focal Access 165 AS3 in a 2015 Subaru Forester.
    Thanks In Advance.
    It may be your Amp overheating, or maybe meron clip protect. Kung new yung forester, highly unlikely under voltage or over voltage.
    #2784
    ^ what's causing the amp to overheat? Could this happen to active underseat subs as well?
    Feb 2017
    #2785
    Thanks In Advance.
    Maxado ka malakas magpa tugtog sir,, kapag lampas na sa capacity ng amp ang volume mo, mag auto protect sya, cut off the amp to protect from damage
    Jan 2018
    #2786
    It can happen when your gain is set too high on the powered sub and volume on the hu
    Jan 2018
    #2787
    Set your gain on your amp and hu the right way for it not to clip. If you have a sub, use 40hz test tone to set your gain properly and Use 1khz for your component speakers
    Adjust it seperately and with your bass boost off, subsonic filter off, your eq flat. There are a lot of youtube videos on this and you can download those test tone for free.
    And remember: amplifier gain knob is not a volume knob.
    Aug 2015
    #2788
    Thanks for the feedback. Jonz is Simplesound. Ano ride mo sir?
    btw, who's jonz?
    #2789
    Quote Originally Posted by phil15 View Post
    sa fd nakalagay.
    ano pala feedback ni jonz sa ryan audio subs?
    Quote Originally Posted by Louie47 View Post
    thanks for the tip bro
    Oct 2008
    #2790
    There also test tones in Spotify. I am also interested in the Ryan Audio underseat subs but wonder how does it perform vs the JBL BassPro SL.
    Regarding the JBL BassPro, I have inquired in one JBL store and available naman sa kanila kaso wala daw harness. Ano yun? Paano gagana yung underseat subs pag ganun? Lol.
audio set-up for beginners [continued]
