Results 2,301 to 2,310 of 3070
- Apr 2017
- 45
April 14th, 2017 02:12 AM #2301
April 14th, 2017 06:31 AM #2302
Medyo matrabaho yata yan idol. Floating subs ang effect. Kasi kapag free air setup na subs, mahina ang dating ng subs. Kelangan talaga may enclosure, that is where it gains more DBs. Also pala, if your rear subs will reflect on your rear windshield, low frequency sound does not gain much unlike tweeters when it reflects on glass.
Gawin mo nalang removable sub. Ganun din ung sa akin para if there is a need to load a lot of things.
April 14th, 2017 09:24 AM #2304
Questions mga sir
Car: Hyundai Genesis
Sound system: Everything stock (with amplifier)
Issue: hissing sound that increases with the vehicle rpm.
What to check? Thanks in advance
April 14th, 2017 01:56 PM #2305
- May 2004
- 65
April 15th, 2017 07:41 AM #2306Ask ko lang may panasonic HU ako at 6x9 oval last 2009 pa di ko pa naikabit. Yung 6x9 nasa car ko but no wire pa dummy lang.
Baka sira na kaya for not using both brandnew naman di ko pa mainstall
- Mar 2013
- 220
April 15th, 2017 11:39 AM #2307
- Apr 2017
- 45
April 15th, 2017 02:50 PM #2308Any reviews on Dr artex and STP Vizomat deadeners? I asked an installer at sabi nya Vizomat>Artex in terms of effectiveness. And butyl ba ang Vizo or asphalt?
6,000 for Dr artex and 6,500 for the Vizo. (2doors inner and outer layer)
May ma suggest pa ba kayo na deadener? Yung pinakasulit para sa price, kahit walang brand or di kilalang brand basta butyl at malupit
- Mar 2013
- 220
April 15th, 2017 03:03 PM #2309Nothing bad about stp sure na ok siya. I use audiomax butyl din (kuripot ako haha), badtrip ang asphalt eh but mura messy nga lang maslalo na pagbinuksan mo uli door panel at magrepair sa loob. Audiomax 650 per sheet, 1.5 sheet per door kung diy pagsila magkakabit 750 to 800 per sheet mlamang gawin 4 sheets sa 2 doors para maykita lol.
- Apr 2017
- 45
April 15th, 2017 03:43 PM #2310
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
