Page 231 of 307 FirstFirst ... 131181221227228229230231232233234235241281 ... LastLast
Results 2,301 to 2,310 of 3070
    Apr 2017
    #2301
    try mo 2MC audio, cabuyao yata location niyan
    Thanks sir. Will call them next week. Sana meron sila, puro Focal/Hertz/Morel nakikita kong seps nila e. Yun din nirefer nilang brands sakin nung nagtext ako.
    Feb 2011
    #2302
    bro G, plano ko 2 x 8" subwoofer lang; konting cut lang dun sa likod; palakihan butas :D
    Medyo matrabaho yata yan idol. Floating subs ang effect. Kasi kapag free air setup na subs, mahina ang dating ng subs. Kelangan talaga may enclosure, that is where it gains more DBs. Also pala, if your rear subs will reflect on your rear windshield, low frequency sound does not gain much unlike tweeters when it reflects on glass.
    Gawin mo nalang removable sub. Ganun din ung sa akin para if there is a need to load a lot of things.
    #2303
    Quote Originally Posted by sientobente View Post
    bro G, patingin naman ng sub ni swift mo
    maliit naman yun sub ko bro, hassle nga lang baklas kabit hehehe
    #2304
    Questions mga sir
    Car: Hyundai Genesis
    Sound system: Everything stock (with amplifier)
    Issue: hissing sound that increases with the vehicle rpm.
    What to check? Thanks in advance
    #2305
    Questions mga sir
    look for the grounding points both the amp and HU, poor body/chassis contact maybe.
    transferring to a much solid panel fixes it sometimes.
    edit:
    RCA cables running along side with the amp's power cable causes noise too.
    May 2004
    #2306
    Ask ko lang may panasonic HU ako at 6x9 oval last 2009 pa di ko pa naikabit. Yung 6x9 nasa car ko but no wire pa dummy lang.
    Baka sira na kaya for not using both brandnew naman di ko pa mainstall
    Mar 2013
    #2307
    Quote Originally Posted by mongze View Post
    Hindi naman siguro wag lang mag-expire ung edge, mine here 8 or 9 yrs ng gumagana ok pa naman malambot lang suspension.
    Apr 2017
    #2308
    Any reviews on Dr artex and STP Vizomat deadeners? I asked an installer at sabi nya Vizomat>Artex in terms of effectiveness. And butyl ba ang Vizo or asphalt?
    6,000 for Dr artex and 6,500 for the Vizo. (2doors inner and outer layer)
    May ma suggest pa ba kayo na deadener? Yung pinakasulit para sa price, kahit walang brand or di kilalang brand basta butyl at malupit
    Mar 2013
    #2309
    Quote Originally Posted by Lzarellano View Post
    Nothing bad about stp sure na ok siya. I use audiomax butyl din (kuripot ako haha), badtrip ang asphalt eh but mura messy nga lang maslalo na pagbinuksan mo uli door panel at magrepair sa loob. Audiomax 650 per sheet, 1.5 sheet per door kung diy pagsila magkakabit 750 to 800 per sheet mlamang gawin 4 sheets sa 2 doors para maykita lol.
    Apr 2017
    #2310
    Quote Originally Posted by joey36b View Post
    Uy gusto ko yan! San niyo yan pinakabit sir joey? Di ko naman need ng branded haha. yung 1.5sheet ay outer and inner layer na??
audio set-up for beginners [continued]
