Quote Originally Posted by kazer View Post
Any kicker users for sq?
Ma consider mo bang upgrade if i change my amps to kicker coming from gladem m line and audio system m line?
Current system is
80prs + focal 165as + jbl sub. + m line 100.2 + m line 75.4.
Simplesound is my installer.
I assume its an upgrade for amp power wise.... Ex amps pala i papalit ko incase.
Why upgrade? Hmm parang listening volume ko kasi with the 80prs is 32-36.
Wav files. Gusto ko naman ang pero parang medyo kulang. :-| . kulang sa kalansing yung mga instrumento. (panay maroon 5, franco at incubus pinapakinggan ko)
Nope! Your problem or concern is definitely not amplifier power related. Your current amplifier is more than enough with the speakers you are using. It's more of a tuning issue. I have no idea with the music material Jonz of simple sound used to tune your system but if I where you I would bring it back and ask him to tune your system using your own music source/material.
Bnew ba yun speakers when you got them installed? Na address na ba nang installer mo yun concern mo in the past? More often that not, some installers would deliberately set the gain structure of your amplifier/s slightly lower to allow your brand new speakers to break in properly. Usually they would ask you to go back after a month or two to have your system re-tuned. This is also the time when your installer will properly level matched the gains on the amplifier. I don't know kase kung nagawa na ito in the past. Just talk to Jonz first re. your concern. I am more than sure he will have the solution. Good luck!
