Results 1,801 to 1,810 of 3070
January 24th, 2016 11:13 PM #1801
Sirs I just bought an AVT underseat slim sub, had it installed by a local auto shop. It sounded good naman po. Lately i think i need to adjust/tune the subwoofer for better sound quality but i do not have any idea how to adjust its phase and frequency and the HUD settings like the high and low pass filter. Meron ba dito parang template nalang to follow your figures/settings, i am
After sound quality lang po..(isuzu mux ls-a and the head unit they told us -avt din po. Thanks in advance..
- Aug 2012
- 2,767
January 25th, 2016 12:36 PM #1803
January 25th, 2016 02:00 PM #1804
Any chance you could bring it back to the car audio shop where you had it installed and let them adjust it for you? Wala kaseng one setting fits all po.
Anyway, you mentioned phase settings. Dalawa lang naman ang setting niyan, either 0(zero) or 180degrees. I suggest you play around with it. The correct setting will be the one that gives you the impression that the bass is coming out from the front dashboard. If you can not tell the difference or if the subs is installed at the front seat or front passenger seat then there's no need to adjust the phase since the subs is already located at the front.
Your active type subs already comes with a low pass filter. Meaning no need to set the active low pass filter on your HU (provided your HU has this feature).
With regards to the cut off frequency. I suggest you start with 200hz then slowly turn the knob down (to a lower frequency) until you hear that the subs together with the other speakers blends together nicely. Meaning neither the subs or other speakers stands out. There is a good chance that you will need to adjust the gain settings of your amplifier as well when you do this.
If you feel that it's quit complicated then I suggest bringing it the nearest car audio installer and have them adjust it for you.
January 25th, 2016 04:01 PM #1805
hi Sir Markygy, thank you for the time. Yes, the HU has this feature, High Pass and Low Pass and the choices are as follows: LPF - "55hz"; "85hz"; "120hz" "through" HPF - "62hz"; 95hz, 135 hz, "through".
i am planning to bring it back to them however my sched been too tight lately, again, thank you and my apologies for this "ignoramus queries" really appreciate it..
January 26th, 2016 11:39 AM #1806
Nothing "ignoramus" on your queries bro, IMHO you are asking the right questions. Better to learn to maximize the full potential of your current gears first before adding or changing them. Marami kase dito gastos lang nang gastos when it comes to car audio but fail to learn the basics and end up loosing interest or not contented in the end. I have to admit though that I was one of these persons in the past, hehe!
Anyway, habang hindi ka pa nakaka punta sa installer mo. Just play around with those settings you mentioned and trust your ears. The correct settings will be the one that works for you. Don't worry as long as you are just controlling the knobs on your HU, walang masisira diyan. Best of luck!
- Feb 2011
- 62
January 29th, 2016 01:58 AM #1807Any kicker users for sq?
Ma consider mo bang upgrade if i change my amps to kicker coming from gladem m line and audio system m line?
Current system is
80prs + focal 165as + jbl sub. + m line 100.2 + m line 75.4.
Simplesound is my installer.
I assume its an upgrade for amp power wise.... Ex amps pala i papalit ko incase.
Why upgrade? Hmm parang listening volume ko kasi with the 80prs is 32-36.
Wav files. Gusto ko naman ang pero parang medyo kulang. :-| . kulang sa kalansing yung mga instrumento. (panay maroon 5, franco at incubus pinapakinggan ko)
- Aug 2012
- 2,767
January 29th, 2016 08:26 AM #1808*kazer: Wow, ang taas ng listening volume mo, 32-26 with amp and sub pa.
I'm only using Pioneer X275BT HU. No amp, no sub. Listening volume ko is 8-10 lang. Already loud and clear.
January 29th, 2016 02:06 PM #1809
Nope! Your problem or concern is definitely not amplifier power related. Your current amplifier is more than enough with the speakers you are using. It's more of a tuning issue. I have no idea with the music material Jonz of simple sound used to tune your system but if I where you I would bring it back and ask him to tune your system using your own music source/material.
Bnew ba yun speakers when you got them installed? Na address na ba nang installer mo yun concern mo in the past? More often that not, some installers would deliberately set the gain structure of your amplifier/s slightly lower to allow your brand new speakers to break in properly. Usually they would ask you to go back after a month or two to have your system re-tuned. This is also the time when your installer will properly level matched the gains on the amplifier. I don't know kase kung nagawa na ito in the past. Just talk to Jonz first re. your concern. I am more than sure he will have the solution. Good luck!
January 29th, 2016 03:14 PM #1810
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
