Results 1,671 to 1,680 of 3070
- Mar 2014
- 63
June 25th, 2015 06:34 PM #1671Hi sa lahat. -Meron akong mono d amp na fusion reactor re-am90010 240 * 4ohms and 350 *2 ohms. Ok kaya mag 1 ohms itong amp na ito? - ok lang ba na 1 voice coil lang gamitin ko sa dual voice coil ng sub? Tia. Ty.
June 26th, 2015 12:19 PM #1672
Which shop can I go to check and rectify the alternator whine in my car audio (preferably a shop in Makati or Pasig). Thanks.
June 26th, 2015 12:56 PM #1673
- It depends if the manual of the amplifier says that your amplifier is stable at 1ohm then it's ok.
- No, it is a bad idea to only use one voice coil of a dual voice coil sub. The performance of the subs will suffer if you do this. Do some searching on how to wire a dual voice coil subs.
- Only wire your subs at 1ohm if you're into burping/dragging the subs or you're after a high number on a spl meter..... It's for the efficiency of the amplifier.
- Mar 2014
- 63
June 26th, 2015 01:54 PM #1674
June 26th, 2015 02:26 PM #1675
- Mar 2014
- 63
June 29th, 2015 12:12 PM #1677
In that case wire your subs at 4 ohms to be safe and hopefully you are using a ported enclosure for the subs. Wala naman consequences if you do this, yun nga lang in the back of your head you know your subs can take in more power.
- Apr 2014
- 473
July 9th, 2015 06:19 PM #1678Hello need help from the experts.
I already have a Pioneer AVH-X5750BT install in my car as well as deadening applied to the front doors (StP Aero).
I still have not decided on what component speakers to buy. I previously owned a DLS RM6.2. I liked it, this time I'd like to consider alternatives.
So far, I'm looking at Morel Tempo and Tempo Ultra. I have not heard the Tempo yet but I have heard the ultra already.
For the amp, dunno what to get. Lol budget is around 8-12k for the amp. I was offered a Sonus amp (forgot the model). For the sub still not decided on the brand but I'm looking at the 8" DD subs. Budget for subs around 5-7k.
Looking for feedbacks on the tempo as well as suggestions on the amp and sub. Thanks.
July 9th, 2015 07:26 PM #1679
- Apr 2014
- 473
July 9th, 2015 10:19 PM #1680
Sec. Dizon and RSA seem to have a really good working relationship, btw.
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
