Results 1,651 to 1,660 of 3070
- Sep 2006
- 143
April 20th, 2015 02:34 AM #1652
Hi mga sir.. Tanong ko lang. About " Trapick Audio" ok ba sir yung shop na to? For loud and clear set up
April 20th, 2015 09:36 PM #1653
April 24th, 2015 12:59 AM #1654
- Jun 2014
- 64
- Jun 2014
- 64
April 24th, 2015 09:53 PM #1656Regarding deadening is it important to deaden the rear doors or the drunk considering sq yung set up
April 25th, 2015 03:24 PM #1657
For me, unless you hear your trunk resonating, then by all means do deadening. For rear doors, if your rear speakers are disconnected, i find more value in deadening the floor and ceiling since those can be the first point of reflection.
Natanong ko na din boss Simon kay Jonz what network mode is on the 5750, parang some sort of full-active capability the HU has that the 8750(not sure of the model) does not have.
- Jun 2014
- 64
April 25th, 2015 10:31 PM #1658Thanks boss so medyo wala rin pala masyadong value for money mag padeaden ng rear door and trunk
April 30th, 2015 02:35 AM #1659
#FYI
I just have deadening on the front doors.
#FYI
May 7th, 2015 12:50 PM #1660
Good day
Considering to upgrade to a pioneer headunit avh-x8750bt from stock unit of montero sport gtv. Question is can I still make use of the rear camera and re-activate tpms? Does winterpine have a toms unit so I can still use the tpms sensors attached to the wheels? TIA
I disagree and wouldn't advise that. Additives get used up too, so topping up with the proper...
Coolant...
