Results 1,571 to 1,580 of 3070
- Mar 2014
- 63
- Oct 2006
- 43
February 24th, 2015 08:47 PM #1573i just grabbed a focal polyglass v2 27 subwoofer. ano po ba mono ampli ang maganda dito?
February 25th, 2015 02:58 AM #1574
February 25th, 2015 05:47 AM #1575
- Mar 2014
- 63
February 25th, 2015 02:28 PM #1576From the plastidip can. It says there that it can be used to insulate and to deaden.
February 25th, 2015 05:52 PM #1577
It will take a lot of plastidip cans to deaden a door. Because the goal in deadening is to increase the mass of the door/enclosure to make it rigid and free from unwanted resonance.
February 27th, 2015 06:24 PM #1578
A better application is to simply try minimizing the area or partially sealing off "leaky" areas.
The concept of sound-proofing is easy. Think of your car as a bubble that is insulating you from outside noise. The more holes there are, the more noise there is. On why the likes of German car manufacturers like Benz and BMW can make their car so quiet (compared to, let's say, a Kia Pride) is their attention to detail in trying to seal the car interior as much as possible from the outside. The likes of Lexus use double-paned glass for example. For Mercedes, this sometimes means using rubber grommets as much as possible to keep noise out as well as thickening some parts of the chassis.
February 28th, 2015 05:42 AM #1579
- Jan 2005
- 41
March 1st, 2015 08:30 AM #1580What is the advantage and disadvantage of using a line converter to connect a active sub to a stock HU that does not have a sub out?
Some other dcts, like dun sa mga 1.6 na hyundai & kia crdis, nagka-issue rin bt. Not sure lang if...
2022 Hyundai Creta
