+1 here. ecu will reset not reprogram once the batt disconnected from the car terminal. for example you may reset the ecu if the idle speed (RPM) is below 600rpm or if the engine stalls etc... similar to the principle of your CP. Your CP will not reprogram/reformat once you took off the batt instead it will reset only.
Reply With Quote![Google Play audio set-up for beginners [continued]](https://play.google.com/intl/en_us/badges/images/generic/en_badge_web_generic.png)
