Results 1,311 to 1,320 of 3070
October 28th, 2014 12:18 PM #1311
Hi sir, does the 25k exclude the cost for the pioneer 265bt already? There is an all JBL package that Simple Sound offers for that price.
https://www.facebook.com/pages/Simpl...10819397926786
- Oct 2014
- 4
October 28th, 2014 12:22 PM #1312
- Jan 2014
- 38
October 29th, 2014 05:20 PM #1313Hi. another stupid newbie here. 01 Sentra GS yung auto ko. Balak kong iimprove yung sounds ko. Been checking out some ads recently and I came across some cheap subs 10" and 12". Tanong ko lang, okay ba na step one ko is magpakabit ng sub na 2nd hand before anything else? nakakita kasi ako 3500 lang sub with built-in amp na. ano massuggest niyo na gawin kong improvement since wala akong balak gumastos ng more than 10k all in na.
sorry medyo newbonoid question
- Mar 2014
- 63
October 29th, 2014 11:10 PM #1314Bos para sa super budget setup mo. I would suggest Akai front component speaker 2500 petot. Pioneer rear g series mga 1200 petot ata. Lightning lab 4100s amp 4ch mga nasa 3700 petot. 10 inch second hand sub ported mga nasa 3000 petot. Wiring kit mga nasa 1000 petot. Estimated 11400. Headunit pa... baka may mas cheaper pa jan bos.
October 30th, 2014 12:16 AM #1315
take it from a fellow newbie. mostly mga expert dito sa Tsikot and sa KAC will tell you pag gusto mo step by step and limited budget ka is to:
1. deaden your doors, pag di kapa satisfied
2. buy a cheap aftermarket sep. targa has good feedbacks. pag di ka pa satisfied
3. add ka amps. preferable 4channel just in case mag dagdag ka nang sub in the future. now pag di ka pa rin satisfied
4. add ka na sub.
or you can go to any reputable shops. Tell them your budget ans see what gears they can come up with.
hope that helps
October 30th, 2014 12:59 AM #1316
the most immediate upgrade on your system will be coming from your speakers. if you change the stock with targa which cost probably less than 2k, the sonic character will change and it might even appear cleaner sounding than what you had before. deadening is a very tricky part, and not everyone will appreciate this upgrade immediately. in deadening, it is like building a solid rigid enclosure around your speaker rather than just adding weight on your doors. when done right, midbass response should improve.
- Mar 2013
- 6,160
October 30th, 2014 10:00 AM #1317What's a really good underseat sub? I'm very particular about trunk space and hence am willing to sacrifice some bass for trunk practicality . Budget not too much of an issue.
- Jan 2014
- 38
October 30th, 2014 11:47 AM #1318Wow! Thank you for all the response! Here's what im planning to do based on my discussion with a fellow SCPH.
1. Replace HU from stock clarion (with cassette pa) to any authentic Pioneer HU (cost around 4500 new)
2. Add NBN sub with built-in amp (cost around 3500 new 2k used)
3. Labot should be around 1k max for HU and sub so im looking at around 9K.
Any comments? I guess this would be my first move muna. Pag di ako satisfied o makulangan, i can opt to change my front speakers first based sa mga nabasa ko dito kaya naman ipower ng 2 front speakers buong cabin.
baka may extra kayong sub or HU diyan hehe. Oh btw di na din daw kailangan palitan alternator ko. kaya naman daw ng stock yun. worse case, may big 3 ako para stable
October 30th, 2014 12:04 PM #1319
A custom one would still be the best one but if there isn't enough space under the seat, a powered sub like this Focal Ibus 20 should fit your needs. As far as I know this cost around 28k from local car audio shops.
Focal Integration IBus 20 Compact 75-watt powered 8" subwoofer at Crutchfield.com
October 30th, 2014 12:14 PM #1320
Just like the Rehab of Boracay. A lot of people hated it, loss of jobs , etc, etc, etc. Look at...
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
