Results 1 to 20 of 3070
Threaded View
    Aug 2010
    Quote Originally Posted by mikedp5 View Post
    Sir jhnkvn pahelp naman po. Currently meron akong pioneer 2din HU tsaka jbl 12in subs. And kinetic dynamic kd6 seps. I know it may be not good seps. Sabi kasi sakin nung pinagkuhanan ko is maganda un sound niya like higher end brands na daw. Un amplifier ko is lightning lab am480. Kaso nasira na and i need to change it. Kukuha sana ako sa states ng amp kasi uuwi un mom ko. Suggestions naman po sa budget amp. And probably seps na mura and maganda na rin. Siguro un seps around 4-5k.
    Eto mga nakita ko na amp. Baka may idea kayo if sulit kung makuha ko sa price niya sa states kasi di ko alam kung magkano sila dito.
    JL audio jx360/4 php6500
    medyo mahal pero kung malaki ang difference than rockford fosgate and justified un pagkamahal niya over sa iba, then sige.
    JL Audio, USA - JX360/4
    Rockford fosgate r300x4 around php5000
    Rockford Fosgate R300X4 Prime 4-Channel Amplifier:Amazon:Car Electronics
    There's no such thing as a bad "properly designed" speaker. Whether this is affordable or expensive. You simply pay for a speaker for its potential to sound good. It's like.. (well, if we have ladies in the house..) makeup. Affordable and expensive make-up isn't really night and day but the more expensive one has better potential. Kung pangit mukha mo, kahit ano gawin mo pangit ka sa majority (the minority will simply use the "eye of the beholder" excuse bwahaha..) Just look at how many South Koreans are undergoing plastic surgery.
    If you're getting JL Audio and Rockfords galing States.. talagang sulit yan. This is because goods coming from the US is expensive in the car audio world thanks to shipping, taxes, and distributor profits. Between the two, I'll get the Rockford. I'm a fan of the JL Audio.. but I'm only limited to the high-end HD lineup ;)
    If you want MY recommendation and you want to use Amazon as a baseline, voila! [ame=http://www.amazon.com/Rockford-Fosgate-R400-4D-Full-Range-4-Channel/dp/B004T0WFVE/ref=sr_1_10?s=car&ie=UTF8&qid=1385752705&sr=1-10#productDetails]Amazon.com: Rockford Fosgate R400-4D 400 Watt Full-Range Class-D 4-Channel Amplifier: Car Electronics[/ame]
    Class D topologies nowadays are very advanced.. you don't need to worry over them. If some idiot in Banawe tells you maspangit sila, tell them sabi ko maganda In a car, they are THE preferred topology is because of efficiency. That's why kahit ang liit niya, it throws more power than your recommendations. How? Read on.
    It's because they're efficient in how they convert electrical energy into mechanical energy. So yeah.. you save energy.. which WILL benefit you by..
    In a car that has its engine on.. the energy is supplied by your alternator. If you pose a lower load sa alternator mo, it won't work as hard. Which means.... better fuel efficiency. Maliit lang though.. like 50 pesos a week lang siguro or something (that's a wild estimate btw) but it adds up. If you want a comparison.. in the world of desktop power supplies, isipin mo 80PLUS Gold certified ka versus... wala.. 60% efficient na PSU.
audio set-up for beginners [continued]
