Results 731 to 740 of 3070
October 16th, 2013 01:36 AM #731
October 16th, 2013 08:04 AM #732
October 16th, 2013 10:15 AM #733
audio gurus, what's the better choice: 10 yr old rockford amp or brand new china amp (kinetic & lightning lab)?
how many watts per channel would be considered as SQ? how about LNC?
October 16th, 2013 05:39 PM #734
October 17th, 2013 02:19 AM #735
How many watts you need... depends on your system. The three most tell-tale indicators are: How loudly do you listen? How is your installation? How sensitive are your drivers?
SQ has never been loudness wars. It has always been: tonality, soundstaging, and imaging. If you do not know what those three are, Google is your friend. For what it's worth, most "SQ" judging sessions consume less than 200W in most cases.
I keep telling people. There's no SQ watts, there's no LnC watts. Watts is a measurement of rate of energy transfer. There's only OUTPUT. You can have a 2000W RMS mono amplifier feeding a 0.75 cu.ft sealed box and my 3 cu.ft ported box with 300W of power will STILL be louder.
People are overthinking your wattage needs and underestimating how powerful 100 watts really is. In fact, when you're simply doing background listening (80dB), you're using something like <20W of power.
October 18th, 2013 09:54 AM #736
- Oct 2013
- 2
October 19th, 2013 01:20 PM #737mga sir ano po kaya maganda na separates para sa innova? 3-4k po yung budget. thank you
- Feb 2008
- 903
October 21st, 2013 07:11 PM #739Noob here....My present audio setup for my Innova vvti 2008 is still the 2din stock audio (no video). Now 7inch tablets are quite cheap nowadays. Would a 7inch tab fit the audio compartment of innova? How about the audio connections or stock speakers of the car would it be workable?
October 21st, 2013 08:00 PM #740
personally, i'd think thrice, before buying that toyota brand new rack and pinion, to fix my 2003...
rack and pinion repair
