Results 371 to 380 of 3070
November 30th, 2011 08:40 PM #372
Mga sirs ok na to for a 15k sound setup:
15k: pioneer deh2350 / lightning lab seps / 1x12 jbl sub / ads650.4 amp / mdf boc / wires / labor.
November 30th, 2011 11:14 PM #373
dagdag ko lang, di ko alam kung paano mag edit ng post.
Yang setup na yan ay para sa Vios 05 1.3E ko po. Di na ba need mag upgrade ng alternator/battery? Ok na ba yang setup na yan? ayaw ko masyado bassy yung tamang base lang yung parang mga 2.1 setups ng computers sa bahay. hehe
December 1st, 2011 01:36 AM #374
I won't comment on the sound setup, however there's no need for any upgrading of the alternator or the battery if you'd be installing those
December 1st, 2011 02:04 PM #376
If I haven't heard it, I reserve my judgement on it. Pangit kasi magbigay ng opinion without first listening to the said components ;)
December 2nd, 2011 01:43 PM #377
December 3rd, 2011 06:22 AM #379
To all Bros /tsikotcitz,
Got Sportivo 2007, 3rd row facing front/folding. Contemplating to "upgrade" my current factory sounds.Newbie din si ako, but loved music and prefer to hear from affordable gadgets. Sa nakita ko sa mga kotse..the so-called "box" is medyu larger in size.This is a question in my thoughts,how to apply on my unit behind the 3rd row seat when sometimes I got baggages in there.Meron pa kayang other options to have a modest sound set-up sa kagaya ng unit ko rear areas usage(dont like roof basket provision)?
Thanks all.
Tsikot Member Rank 4
- Jun 2006
- 2,605
December 3rd, 2011 08:40 AM #380Sportivo,
Easiest way is just to get a decent HU, a 4 channel amp a pair of seps for the front stage. I normally dont use rear fill but since the Crosswind is a big car then you may want to use a pair of coax for the rear. Ask your instaaller if he can fit a 8 inch shallow mount sub in a small sealed box under the front seat. I've seen pics of this done in a innova. IIRC, they used Polk DB subs. It wont give you monster bass but it should sound good. Mind you it wont be easy to do.
Or just get a small sealed box and put the sub at the cargo area. Sealed boxes are usually smaller than ported boxes. They are also more accurate and musical. However, they dont put out as much bass.
If you are willing to spend for custom work, I've seen a guy install a 8 inch sub on the side of a BMW diesel SUV. It really looked stock. he placed the amps on the other side wall. But that kind of setup will cost big bucks. Be prepared to shell out mucho money for custom fiber glass works.
It may be variable speed I think. It's slowly being used on cars that either don't have an ICE, or...
A/c
