Results 1 to 20 of 3070
    Jan 2010
    kind sirs,
    will the system below be a good basic SQ set-up?
    Amp: Powerbass ASA600.4
    Seps: Firland EV602 (then later move to rear side doors when add'l budget is raised for a Cadence ZRS-6K)
    Sub: 1pc Powerbass PS10 (or any recommended 10" sub)
    would like to retain the JVC KD-BT22 unit on the car. i believe this will go around the range of 20k-down. will this work sirs appreciate your inputs.
    thanks in advance.
    Quote Originally Posted by jnh01 View Post
    kind sirs,
    thanks in advance.
    ang lakas ng amp mo sir! hehe
    yung mga speakers have the risk to be overdrivien. subs at 225 rms and 65rms seps. kaya output ng amp would be 400 rms bridged.
    i would say na change the amp to rockford fosgate p500-4. sakto lang lang sa subs (busog) then change the seps to DLS R6A. 160 rms nito. clear and crisp sound.
    Jan 2010
    kind sirs,
    thanks in advance.
    Quote Originally Posted by archie123456789 View Post
    thanks sir archie! will consider the RF amp and the DLS seps. sir, could you give me an idea how much each costs, also where i can buy them? major! major! thanks! thanks!
    im not familiar with prices pero alam ko around 20k - 30k RF amp brandnew the DLS mga 10k - 15k ata. im not really sure. hindi kasi ako nagsesetup ng sounds. hehe
    if you can get a set of seps na meron 225 rms, mas ok kasi busog ang buong setup. im not sure what brands have this. i think morel has a seps set that can handle 225 rms. ask around lang po.
    you can buy it from any sound setup shop. those brands are not usually available sa mga low end shops. candy shop sa banawe has them, mickeys up north, kid audio, im not sure if jeff tan at araneta car accessories have them.
    Nov 2006
    makikidaan lang. mas ok ba kung ako na lang magsetup ng audio ko? para wala ng kelangan bayaran na labor.
    kaso may school ba na pede ko matutunan yan? yung shourt course na ok naman sana ang result.
    wala kasi ako background sa electronics.
    sana may masuggest kayo. napapahilig kasi ako magbutingting. at iba na rin kasi kung may alam ka compared sa kung aasa ka lang sa gawa ng iba, hindi ka matututo
    tnx
    ^^ try meralco for electronics.
    kung kaya mo DIY sound setup, by all means do it. mas masarap pakiramdam na ikaw ngsetup.
    Nov 2006
    ^^ gusto ko nga mag DIY sana kaso wala pa laman kokote ko
    kelangan ng konting hand-on at lecture. sana makatulong yung sa meralco pag nagenroll ako.
    may nakaattend na ba dun in regard to car electronic?
audio set-up for beginners [continued]
