Results 1,241 to 1,250 of 1645
May 24th, 2008 01:00 PM #1241
v6,
hehe i thought the issue was as simple as installing the second amp right away. anyway, ill try to check my alternator kung kaya niya. otherwise, i'll have to stick to a one-amp setup.
May 24th, 2008 09:31 PM #1242
- May 2008
- 4
May 29th, 2008 05:07 AM #1243sir i just want to ask meron po kc ako subs n 15 inches nka sealed box po sya! ok lng po b un? nka seps po ako ng targa 6 inches my amp po ako n v12 ung alpine ung orig ko secong hand ko lng po nbili un eh!805 UNG AMPLI KO sir kung mg bbago po ako ng set up anu po b m advice nyo kc fx po ung sskyn ko ung buong likod ko po kc sounds lng nka lgay so!anu po b mg mlkas ung 15 incnh n lanzar audio or 2 kicker 12 inches salamat po
May 29th, 2008 05:55 AM #1244
May 29th, 2008 10:11 AM #1245
- May 2008
- 4
June 2nd, 2008 09:19 AM #1247
RF or kicker amps can do justice for the 2 12" kickers... look at the RMS of the subs then look for the same or higher wattage for the amps.
if budget permits, L5 series have excellent boom boom power
June 21st, 2008 04:52 AM #1249
mga sound gurus.,plano ko pong iset up ang sound system innova ko,wala naman akong idea kung paano,gusto ko po sana yung crystal clear and crisp ang sound sa loob at syempre yung solid bass,problema ko kung abutin ng budget ko for 30k.,ok na po ba yun?
- Jun 2008
- 3
June 22nd, 2008 11:03 AM #1250audio masters, i'm just new here in tsikot.yehey.com, gusto ko lang po sanang humingi ng advice mula sa inyo about setting-up a nice and quality sound for a Toyota Corolla 94 XE. what do you recommend for starters? yung surround sounds with base...sorry, amateur talaga ako sa audio. maraming salamat mga master!
sa akin, ang question ko is why some mild hybrids (e.g. Ertiga) made it to the list, while others...
Suzuki Fronx
