Need help regarding my set-up. wala akong masyadong alam sa pagseset-up ng sound, gusto ko lang pagaralan at mag-upgrade.
my set-up is this.
*pioneer P5850MPH HU
*1x12" CVR kicker 4ohms dual voice coil RMS 400w-peak 800w
*1x lanzar244(2channel) - 1x1000w *4ohms bridge / 2x250wRMS *4ohms /2x420wRMS *2ohms
*1xV12 1200w for kicker interior mids/tweets/coax
Tanong ko lang kung magdadagdag ba ako ng sub e kakayanin nung amp? balak ko kasing magkabit ng 1 pang CVR12 tapos parallel connection for each sub to make it 2ohms each which can be drive by amp base from the specs, ang connection e each channel per sub (amp is 420wRMS*2ohms then sub is 400wRMS*2ohms). Kaya po ba o mali ang iniisip ko?
The other thing is, lets say parallel yung connection nung dual voice coil to make it 2ohms each, then kung i-series ko ba itong 2subs (to make it 4ohms tapos naka-bridge amp ako with 500wRMS) ko e double din ba ang kailangan ko na wattage from my amp,what i mean is kung yung 1sub e 400RMS each (2x400wRMS=800wRMS), 800wRMS ba na amp ang kailangan ko or 400wRMS lang ay puede na? Maraming salamat po sa inyo...
