Good question. With so many in-dash stereo's to choose from, how do you pick the right one?
Before I answer your question let me ask you a little about your basic objective, how far you will go to get the system you want. You dont have to answer this into me but yourself.
Now,Learn about products and technology youll find what to look for and get the detailed product info, create comparison and look for product review. If you starts from scratch get a stereo w/ at least 2 or 3 preamps outputs for your expansion option on a later date. This is your first step. You dont have to buy the whole system for now but you can built it little by little.
Next is speaker. Buy a good speaker with higher sensitivity rating, the louder it will play from the amount of power it receives.
Recomended for front speaker is component system or two way maybe tri way depends your way of listening. Rear is 6x9 or 6 1/2. This is your second step toward your target.
Amplifiers. Buy a four channel amps to bypass your stereos amps for more better impact. Make sure to buy an Amps with a preamps output for your next expansion of you system. Preamp output means is you could connect your amps with another amps for your sub w/o buying separate crossover.
This is your basic set up that can upgrade almost endlesly. This for now and remember if you do your homework the first time, could save you a lots of money. Hindi yung, ay mali sana yong mas malakas ang binili ko. if that thing happen gastos na naman.![]()
