Results 1 to 20 of 1645
    May 2007
    Quote Originally Posted by c_lee89 View Post
    mga bossing, tanong ko lang kung ano ang tamang wire size para sa power cord ng amp tsaka speaker wire para sa subs.. i'm using a 600W RMS na monoamp tsaka audiobahn sub na 500W RMS. isa lang po yung sub ko. gauge 8 yung power cord ko ngayon tapos d ko alam yung sa sub wire.. baka kse undersize yung gamit ko, sayang naman pag d mamaximize yung power ng amp.. tnx in advance.
    For Sub.
    Thicker wire-10, 8, 4, 2 gauge ang maganda depende kung gaano kahaba ang gagamitin mo sa lakas ng power amplifier at kung anong balak mo gawin.
    Sa Amps na may put out na 50 watts x 2 channels o kaya 25 watts x 4 ang 10 gauge ay pwede na. Kung balak mong ilagay sa trunk ang Amps mo at gusto mo ang malakas na togtug, 8 or 4 gauge ang gagamitin mo. Laging tandaan na ang Amps ay require a lot of current to handle loud, low bass notes, and the thicker the wire, the more current it can deliver.
    "CABLE LENGTH"
    Amperes ----12gauge ----10 gauge ----8 gauge ----4 gauge ----2 gauge
    125-150 ----4-6ft --------7-10ft -------11-14ft ---- 15-19ft ----19-22ft.
    105-125
    85-105
    65-85
    50-65
    35-50
    20-35
    0-25
    Current estimate.
    First, add up the fuse rating of all your Amps. Now figure your amps total steady state average output(divide total RMS wattage by total peak wattage). Then multifly your fuse rating total by your Amps total steady state average output. This gives you a rough estimate of how much current your sound system is going to require.
    Estimate your electrical systems reserve current capacity..
    Tingnan mo yung alternator amps rating and multifly it by 40 percent. Ito ang pinakamalapit na base line estimation ang electrical reserve
    capacity ng iyon kotse. Halimbawa, kung ang alternator ay may rated na 90 ampere, 90amps x 40 percent = 36 amps na lang ang natitirang power sa sounds system mo. Kung ang figure mo ay mas mataas kesa ito your in good shape.
    Needs more advance about details of perfections just ask.
    boss userfriendly question ulet,, pwede ko ba ikabit lahat ng channel ko sa seps ko na 2way? yun amp ko yun mtx4244
    Jun 2006
    Quote Originally Posted by ammad View Post
    Pwede bridge channel 1 and 2 and connect to right speaker. Bridge 3 and 4 and connect to left speaker. Just make sure both crossovers are set to high pass or all. If all make sure you have passive xovers on your seps. However, I think it this will give your seps too much power, 200 watts each. If I remember correctly your seps are rated for around 60 watts, tama ba? Baka pumutok ang speakers mo. Also, take note that this setup will be hard to tune. I think you will be in mono.
    Quote Originally Posted by userfriendly View Post
    ahh thanks,, so talagang 2 channel lang mabibigay ko sa kanya opo 60rms lang yun seps ko,, thanks po sa suggestions
audio set-up for beginners (ARCHIVED)
