Results 1 to 20 of 1645
    Quote Originally Posted by userfriendly View Post
    You can bridge 2 channels of the amp to power your sub.
    ahh so hindi pala pede lahat ng channel kabit sa sub para lumakas pa...
    sir yun rms ba yun rated input power?? nakalagay kasi sakin 380 watts tapos peak power 1300
    about po pala sa rear speaker ano po maganda ikabit? 97' mazda familia po pala yun ride ko,, salamat po sa mga suggest mo..
    Jun 2006
    Quote Originally Posted by ammad View Post
    Baka pwede. I'm not sure. Can someone pls verify if this is possible.
    If you have a dual voice coil sub, I think you can bridge one channel and connect to one voice coil and do the same for the other channel and voice coil.
    Theoretically it can be done. But I've never tried or seen it done.
    I'm doing it. I have a DVC 12" Targa. 100x4rms Thunder audio powering the sub. I got it done at Jeff Tan's shop.
    Jun 2006
    Thanks for the fast reply.
    boss pede po ba na dalawa ang ibridge ko sa amp ko?? mtx4244 eto po spec. niya
    rms power measured at 12.5 volts Dc
    45x4 into 4ohm less than 1%thd
    60x4 into 2ohm less than 1% thd
    120x2 bridge into 4ohm less than 1% thd
    dynamic power measured at 14.4 volts dc
    55x4 into 4 ohm load
    100x4 into 2 ohm load
    200x2 bridge into 4ohm load
    Jun 2006
    Pwede. You actually answered your own question "120x2 bridge into 4ohm less than 1% thd" BTW, you have a unregulated amp. This means you get more power when your alternator is giving out 14.4 volts compared to 12 volts. That's the difference between your dynamic power and rms power.
    And as I said before, your amp is under rated meaning those power ratings are very conservative and the amp will pump out more than that.
    salamat po,, yun balak ko kasi channel 1 and 2 bridge sa seps. ko tapos 3 and 4 bridge sa sub ko,, btw 60rms po yun seps ko and yun sub ko 380rms ok na po ba yun set up na ganito??
    Quote Originally Posted by KrisKros View Post
    tol magkano score mo kay jeff??
    ygpm
    May 2005
    question guys.
    my pioneer HU has only 1 pair of pre-out (?) for amp.
    now i have gotten hold of some seps and a 4ch amp.
    i'm planning to connect the seps and the stock 6x9 na kenwood speakers dun sa amp na 4ch. is this ok? or better if I let the HU power the seps and connect the 6x9 to the amp?
    May 2005
    Follow up question po.
    yung amp ko is the cheapo v12 na 800W 4CH.
    Am I better off not using it? and just connecting all the speakers (seps and 6X9) directly to the HU.
    HU ko is DEH-1750
    in my opinion, better to connect your speakers to the amp. To amplify the sounds. Plus, if your amp has crossover settings, you can play with that to get a custom sound to your taste of sound. I think it will sound better off of the amp.
audio set-up for beginners (ARCHIVED)
