Results 631 to 640 of 1645
May 16th, 2006 01:35 AM #631
Originally Posted by Mitzel
Still, best recommendation is to audition other installed systems within your budget.
- May 2006
- 3
May 16th, 2006 12:00 PM #632thanks wild thing. what are your recommended shops? the only shop i know is g audio. pardon the ignorance, but what do you mean when you say, audition? thanks again
May 18th, 2006 05:02 AM #633
I was reading something in the NissanBayan Forums..and there was something about a P5,000 sound system.
Here it is below:
.....ok, an all targa setup is nothing new to us you might say. but what set this car apart from the others is that, all are running via HU in 2 ohms. the speakers are 4 targa coaxials front and rear wired parallel through the HU's front speaker level out. the rear speaker out powers the 2 x 10" targa running IB(free-air). his HU btw, is a pioneer(forgot the exact model)...but it's the same series as the 7450.
once in the driver seat, i noticed that the sound was pulled all the way to the back where the 2 coaxials and the 2 x 10" subwoofers. ok, imaging is not its strong suit. but the tonal balance is something you will be amazed with. in fact, if you take-out the imaging in the equation and just based in on it's overall tonal balance...this car would easily put to shame most setups with a budget 3 to 5 times more......
U can hook up a Subwoofer without an amp? or does this guy have an amp?
May 18th, 2006 11:44 AM #634
kapag nilakasan ko yung sounds ko...yung speaker sa likuran, parang basag ang tunog. may vibration. di ba compatible ang HU ko at speaker ko??
- Nov 2005
- 13
May 19th, 2006 02:21 PM #635Originally Posted by badsekktor
Tsikot Member Rank 4
- Jan 2003
- 2,979
May 22nd, 2006 02:26 PM #636ask ko lang bakit minsan yun sounds ko humihina ng konti.. di ko naman inaadjust yun volume. tapos pag pinatay ko yun HU at binuksan ko ok na naman. ano kaya problema nito
May 29th, 2006 03:25 PM #637
are the small tweeters placed on the dashboard really necessary for a better sound reproduction? di ba enough na yung smaller speakers in the front portion of the cabin...yung mga usually located beneath the dashboard or on the front doors of the car?
- Jun 2006
- 19
June 4th, 2006 12:11 PM #638Originally Posted by the_wildthing
ano po bang shops na recommended nyo for installation of audio set up within qc? or kahit sa raon area baka po ma recommended shop kayo na trustworthy?
TIA
- Jan 2003
- 2,979
June 5th, 2006 02:26 PM #639Originally Posted by baludoy
Looked at their other videos and seems to be a lot of doom and gloom.
China cars
