Results 1 to 10 of 15
- Jan 2007
- 24
February 26th, 2007 01:41 PM #1Mga experts,
I had no problems with my audio system, until last week. Whenever I rev the engine of my car, the amplifier goes OFF. Ung green light nagiging red. I would turn off the stereo for a few seconds, then turn it on again and the amplifier would work. When I rev the engine......patay nanaman. What could be the problem???
February 26th, 2007 01:55 PM #2
- Jan 2007
- 24
February 26th, 2007 05:48 PM #4
You amplifier might be getting into auto protect mode.. check your gain settings, might be too high, it shouldn't go over 1/2. 1/4 would be an ideal setting.
- Jan 2007
- 24
March 2nd, 2007 03:13 PM #6I tried to lower the gain to 1/4 to 1/2 just as you suggested....ganun pa rin....nag pro-protect if I rev my engine..
March 3rd, 2007 09:04 AM #7
check the voltage output of the alternator, baka when you rev it it goes over 14.8 volts nag proprotect ang amp.
- May 2005
- 36
March 4th, 2007 09:39 AM #8try mo disconnect mga speaker terminal sa amp, then rev, then observe kung mag protect pa.
tighten the ground, remote and battery teminal ng amp, baka loose.
- Jan 2007
- 24
March 7th, 2007 02:24 PM #9I tried all your suggestions.....nothing worked. Mas malala nga ngayon e: OK ung amp na tumutugtog when the engine is not running. but when I start the engine....nagpro-protect nanaman
Driver/PasaHERO
- 1,310
March 25th, 2007 07:40 PM #10baka masyadong malakas binibigay na voltage ng alternator, gano katagal bago mag protect ung amp when you rev? nangyayari ba to kahit kaka bukas mo lang ng engine tapos ni rev mo(namamatay agad ampli?)...pag nagawa mo na lahat ng suggestions dito at ganun pa din, patulong ka na po sa professional
high idle RPM at engine start
