Results 1 to 10 of 19
March 16th, 2004 03:10 AM #1
San ba meron nito? For corolla gli big body. to eliminate power problems
March 16th, 2004 11:32 AM #2
try using capacitors muna ser.. mahal ata ang alternator e.. suggestion lang naman...
March 16th, 2004 12:09 PM #3
Yup, capacitor na lang dagdag, pag di pa rin kaya tsaka upgrade ng alternator.
Usually ang kinakabit nila ngayon na high ampere alternator ay galing sa Hyundai na 115 rating. Binabago nila ang mounting brackets to accomodate. Depende sa gumagawa kung mapapantay ang alignment ng pulleys.
Kung gusto mo naman ng stock brackets, kadalasan 85 amp rating pinagkakasya nila sa stock 65 amp housing.
- 26
March 18th, 2004 04:18 PM #5
Usual stocks are around 45 amperes. But I have seen some units with 65 amperes as stock.
March 18th, 2004 05:59 PM #6
gamit ko ngayon reconditioned alternator... nag konk-out na kasi yung stock ko eh... 90amps na from the previous 75amps. 4000 lang kuha ko (through my mechanic)
- Mar 2017
- 4
October 28th, 2017 04:47 PM #7ilan amp ba dapat ang alternator ng 97 Toyota Corolla A/T na lolow batt kasi ang Battery ko😊 s thanks sa mag rereply👊👊👊
- Jan 2010
- 283
October 28th, 2017 05:51 PM #8The standard alternator capacity rating is 70 amperes.
Why the bigger alternator?
Does the state of charge drop overnight?
Do you have electrical load add ons?
Do you drive mostly short distances?
Effect of a larger alternator is higher fuel consumption and additional weight to the car.
- Mar 2017
- 4
October 28th, 2017 08:26 PM #9
- 52,731
October 28th, 2017 08:31 PM #10have your alternator seen by an alternator specialist, po. (yock's comes to mind.) they'll also check your system, to make sure that it is indeed, the alternator...
sometimes, all that is needed is to replace the electronic module inside. it's still cheaper than purchasing a used or new alternator.
and, done properly, it'll last many more years.
of course, purchasing a brand new alternator is an easy fix.
the assumption is, you do not have any power-hungry appliances in that car.Last edited by dr. d; October 28th, 2017 at 08:35 PM.
high idle RPM at engine start
