Results 1 to 6 of 6
October 24th, 2003 11:36 AM #1
konzert 12 inch sub 350 watts dual impedance
daichi blaster mosfetcomtrolled 300 watts X2 bridgeable
the sub has 4 terminals.does it mean its equivalent to 2 subs? dual impedance? does it really mean its equivalent to 2 subs? will the amp be able to power this single sub?
October 24th, 2003 02:01 PM #2
Dual Impedance = Dual Voice Coil
It doesn't mean that it is equivalent to two subs. For a single sub to sound like 2 subs, it must be able to push twice as much air. Therefore look into displacement, power and Xmax if you want to see if a certain sub will sound twice as loud as another sub.
To know if your amp will handle this sub, check the impedance of the voicecoils and make sure when wired, the final load matches the minimum bridged impedance of the amp.Last edited by Beefy; October 24th, 2003 at 02:04 PM.
October 27th, 2003 03:22 AM #4Originally posted by notEworthy27
how do you measure? use a tester?
October 28th, 2003 09:14 PM #6
The manufacturer provides the impedance of its subwoofer or amplifier.
Check the spec if the sub is dual 8ohms, dual 4ohms or dual 2ohms.
As for the amp, check if it is bridgable and up to what load(e.g. 8ohms mono, 4ohms mono, 2 ohms mono)
Hybrids and EV
