konzert 12 inch sub 350 watts dual impedance
daichi blaster mosfetcomtrolled 300 watts X2 bridgeable
the sub has 4 terminals.does it mean its equivalent to 2 subs? dual impedance? does it really mean its equivalent to 2 subs? will the amp be able to power this single sub?
It doesn't mean that it is equivalent to two subs. For a single sub to sound like 2 subs, it must be able to push twice as much air. Therefore look into displacement, power and Xmax if you want to see if a certain sub will sound twice as loud as another sub.
To know if your amp will handle this sub, check the impedance of the voicecoils and make sure when wired, the final load matches the minimum bridged impedance of the amp.
