Results 1 to 7 of 7
- Oct 2014
- 34
January 23rd, 2016 04:13 AM #1Mga sir may nakaexperience na ba sa inyo na may static sound un sa headunit? Di sya rinig kpag may audio pero once I turn off the volume naririnig ko un static sound na.. I'm going to have it check na rin sa casa tomorrow.
Pero just in case may mga idea kyo sir sa problem I'm all ears.. Thanks guys
January 25th, 2016 08:42 AM #2
have the wiring checked. most likely there is a loose or grounded one somewhere dyan sa HU.
January 25th, 2016 11:26 AM #3
May kinabit ka ba car audio gear lately or everything is oem stock? If everything is stock, then you should check your battery. A whining sound coming out of your speakers is one indication that your battery is about to fail. Kung nag palit ka naman nang HU lately or added for example a external amplifier then hanapan mo nang bagong grounding point ang either HU mo or yun external amplifier.
- Oct 2014
- 34
February 16th, 2016 05:30 AM #4
March 30th, 2016 04:19 AM #5
Any update d2 mga sir? I have the same thing. Before 1 amp lang ako for my raw drivera and amp. Ok naman before, when i added a mono amp, it started. Same ang grounding point ng 2 amps, under sa screw ng driving seat.
New din yung HU, ill try chaging the ground ng amps ko. Post ako update.
March 30th, 2016 04:20 AM #6
Also kapag pinatay ko yung stereo, ill hear a sound na parang sumabog. Static daw, san kaya galing.
March 31st, 2016 01:35 PM #7
byd seal5 dmi. that coolant tank is the same setup like in the fords. plastic coolant lines :twak2:...
BYD Philippines
