Page 25 of 26 FirstFirst ... 15212223242526 LastLast
Results 241 to 250 of 251
  1. #241
    Join Date
    Jul 2011
    Default Re: Avanza Engine Problem
    guys, patulong naman..
    yun avanza ko 2007 model pinacheck ko pang ilalim ang suggest ng mekaniko palitan yun suspension arm bushing small at big one.
    at yun stabilizer link pinalitan ko narin ng 555.
    before ako nag paayos bumyahe pa ako ng batangas at nakakatakbo ng 120 speed. no problem sa steering wheel
    now after palitan yun bushing at stabilizer link, bumyahe ako ng baguio 80 or 90 pa lang sa nlex nag wewiggle na steering ko.
    tapos ang daming lumalagatok na sa ilalim. medyo duda ako dun sa bushing na pinalit kasi at first nag hesitate sila dahil iba ang sukat..
    san kaya ako makakabili ng magandang bushing? or need palitan buong suspension arm ng original?
  2. #242
    Join Date
    Quote Originally Posted by alx View Post
    installing "iba ang sukat" onto the suspension system, is a bit of a gamble, in my opinion.
    it might not be defective, but really, just "different".
    perhaps your problem will be solved if you simply replace the part with the truly appropriate one.
  3. #243
    Join Date
    Jul 2011
    wala daw kasing original na bushing lang for avanza.
    if original i will need to replace the whole arm..
  4. #244
    Join Date
    Jul 2013
    saang shop mo sya pinagawa?
    I honestly don't believe the mechanic saying di sya makabili ng bushing lang... It's a Toyota...
    Plus the Avanza has been around for so long, impossible na wala syang makitang parts.
  5. #245
    Join Date
    Jul 2011
    sa may roosevelt. yun mga mekaniko sa labas ng auto supply.
    i guess i have to change the orig suspension arm na. wc cost 10k per side!
    wala talagang kasukat na replacement bushing.. =(
    hindi na ba active mga vanzy owners?
  6. #246
    Join Date
    maybe that is why toyota does not sell the rubber thing alone.
    maybe toyota meant to have the entire arm replaced.
    i remember another (non-toyota) car from some years ago.
    sinubukan ng owner na palitan lang ang rubber bushings ng suspension arm.
    "hindi nagtagal" ang repair.
    he ended up replacing the entire assembly, which remained ok until he sold the car, years later.
  7. #247
    Join Date
    Jun 2005
    Default Re: February 2010 ACP EB
    Kunin mo lumang piyesa. Punta ka banawe. Isa isahin mo tindahan dun. Sigurado ako meron nyan.
    Kutob ko hindi maganda pagkapress ng bushing kaya sablay sayo
  8. #248
    Join Date
    Jul 2011
    Quote Originally Posted by sirkosero View Post
    medyo naiinis na ako kasi ang daming lumalagatok sa ilalim.
    called up lots of auto parts including toyorama na. wala talagang orig bushing.
    il just order buong suspension arm na. wasted 4k for that bushing, labor, at machine press in/out!
    unless meron tayong ka member nakapag replace ng bushing at successful..
  9. #249
    Join Date
    Jun 2005
    Wala talaga Original bushing. Lahat replacement.
    Usually ang big buahing parepareho lang naman. At most, susukatan mo lang yan ng diameter.
    Sana natry mo sa wheelers, zee or cruven. May nakasabay ako dati sa zee na.avanza, wala naman naging problem sa parts.
    Its a toyota. Sabi nga ng mga mekaniko,Kahit sa sari sari store may mabibili kang piyesa.
  10. #250
    Join Date
    Jul 2011
    nagtanong narin ako sa wheelers. ang suggest nya orig na buong susp. arm nalang ipalit. napilitan na ako umorder sa toyota..
Posting Permissions
  • You may not post replies
  • You may not edit your posts
