Results 211 to 220 of 251
Thread: Avanza Engine Problem
May 3rd, 2012, 07:25 PM #211
- Oct 2008
- 8
Re: Avanza Engine Problem
question po..newbie lang...pano ba inaadjust ang idle ng avanza j (2007), npapansin ko kc pag traffic umaabot ang idle ko ng 1.5 kahit naka neutral lang at nakahinto...normal ba to? tia
May 4th, 2012, 11:54 AM #212
May 4th, 2012, 12:13 PM #213
- Oct 2008
- 8
thanks....anong recommended nyong shop...malapit sa banawe...
August 16th, 2012, 03:40 PM #214
- Oct 2008
- 8
guys....follow up lng...may DIY ba para i-adjust ang idle ng avanza? tia
August 16th, 2012, 06:28 PM #215
August 16th, 2012, 06:32 PM #216
subukan nyo sir i reset yung ECU.. disconnect nyo yung battery for a few mins..
August 17th, 2012, 01:48 PM #217
- Oct 2008
- 8
salamat po sa enlightenment ... may recommended shop ba kau or casa talaga nagrerepair ng ganitong issue
September 7th, 2012, 11:01 PM #218
- Sep 2012
- 5
Mga sir.. help nmn po.my prob po ako sa vanzy ko, kc po pag nkarekta na ko mga 40-50kph na, my tumutunog na sa makina, parang yung tunog pg maluwag na ung belt.. minsan nmn parang tunog ng turbo... pero lumalabas lang yung tunog pag mainit na yung makina,yung tipong mga 20-30 mins na kong tumatakbo pero po pag arangkada wala pong tunog, anu po kaya un? Please help nmn po mga sir.
tnx M/T po pla vanzy ko.
September 25th, 2012, 12:37 AM #219
- Jun 2007
- 13
Gudpm to all, just bought a second hand 2007 avanza g at 49tkms reading,manual transmission, ive checked if its flooded, and its not. Question lang po mga sir, kasi when i test drove it ok naman, pero nung pauwi na kami after thepurchase, napansin ko pag shift ako third gear, sometimes kumakadyot sya upon 3 to 4rpm, pero minsan smooth naman.i dont know if the correct term is JERKING? Anyway pinascanner ko sya sa , wala naman mga faults sa sensor everything was fine daw, hindi lang daw ako sanay, so i drove my tita's avanza in the same manner pero di sya kumakadyot, ive tried all themechanics here in our place pero wala makapinpoint, hindi kasi consistent ang problem, at hindi palyado ang makina, minsan maayos manakbo, kayaginagawa ko pag kumakadyot ng malakas tinatapakan ko nalang ng malakas ung accelerateor... So dissapointed, as of now wala pa ako budget for casa.... Ask ko lang if may naka experience na nito sa inyo? At kung ano kaya possiblecause?
September 25th, 2012, 09:08 AM #220
Safe ba sa emblems yung bug and tar na made from HCl? Yun kasi yung kinuha ko. For my polishing set...
"Tamang OC lang" - a newbie's guide to car...
