Results 1 to 13 of 13
    Feb 2005
    which brand and type(foam, microfiber, etc) do you prefer? how much did you get it and where from?
    foam wax applicator pads are about 65 to 80 pesos each depending on where you buy them. most common ones are the meguiars and the generic ones sold by blade.
    i use only the generic or any foam like uratex. the more you wash it the more it softens for the next use
    Feb 2005
    what is the likelihood of swirling your paint with foam applicators?
    Mar 2004
    Quote Originally Posted by pachanga View Post
    Unlikely. The only thing I can think of is if you accidentally drop your applicator sponge and you continue using it instead of getting a freshly cleaned one.
    no swirls will be produced as long as you don't use it (foam) for rubbing. if machine use, there might be a little but it will dissapear (hidden) after polishing and buffing.
    Feb 2005
    thanks for the replies.
    i'm planning to get some of those sm arnold brand foam applicator pads this weekend. :D
    Feb 2005
    wonder what's the difference between the violet meguiars (usually comes with nxt) and the yellow meguiars (sold off the shelf)?
    Mar 2004
    Quote Originally Posted by spyghost View Post
    Pareho lang yon... I have both. I think the ones that came with NXT were just colored violet/green to match the color theme of the product.
    Apr 2009
    Just plain ordinary sponge will do the waxing. it's dirt cheap considering the price of those so called just for waxing type. It's the same....
    the most important part of waxing is the buffing part.
    Feb 2009
    FYI lang po. Yung Zwipes may binebenta na microfiber cloth with FREE 2 applicator pads for only 150php. Sa ace hardware meron po ito.
    Feb 2005
    update:
    i tried using makeup sponge as my wax applicator. seems to work fine: no swirling and spreads the product thinly and evenly without absorbing too much of the product in itslef. :D
wax applicator pads
