Results 11 to 20 of 23
- 45
November 4th, 2002 06:47 PM #11i use WD40 rin sa mga maliliit na spots ng tar and asphalt. medjo mahirap lang tanggalin yung mga medjo malalaki at makakapal na tar using WD40.
November 5th, 2002 09:53 AM #12
yeah, you need to do it again and again until the thick tar thins out... hassle... parang snot hehe...
November 5th, 2002 12:48 PM #13
In my case, MC works fine for me:D Cheap din, at P30 a pop. Just remember to wash your car after, hehehe
November 5th, 2002 01:42 PM #14
ako as what theveed is using is yung spray on 3m tar remover. effective sya. easy to use pa (parang endorser ah.):mrgreen:
- 61
November 5th, 2002 08:14 PM #15ok to ah, ako nga may mga tars din sa gilid. Ngayon ko lang na REALIzE na TARS pala yung mga dark spots sa may fenders and ilalim ng rear bumper sides. So bili nalang ako ng 3M tar remover.:roll:
Thanks a lot guys, its nice to read, read, read.....this informative stuffs.
- 17
November 6th, 2002 04:24 PM #16theveed,
how do i remove asphalt/tar that has hardened already? i tried kerosene to no avail . . . but my procedure must have been wrong kaya di natanggal. kaya ba ito ng tar remover? thanks.
November 6th, 2002 05:14 PM #17
Tar doesn't really harden, it may thicked due to quantity, but di sya titigas...
The key is to scrape away the tar little by little from the top. Meaning, ang objective mo is not to scrape the thick tar off the paint, but to thin the tar to a level na matatanggal na sya sa paint ng kusa...
Visualize mo isang mountain, you scrape the tip of the mountain konti konti (using tar remover or kerosene and cloth) then keep scraping the TOP off until the mountain is level to the ground... At this point, just soak the tar and it should wipe right off...
- Feb 2008
- 8
March 28th, 2008 04:21 PM #18Mr. Theveed,
How about on overspray of rusproofing paint on a 2 month old repainted surface? Will the bug & tar remover or WD40 be safe to use to remove those overspray?
March 28th, 2008 04:52 PM #19
Xiaomi E-Car
