Results 7,291 to 7,300 of 7834
November 17th, 2019 12:02 PM #7291
Ako it depends hehe siguro wala na rin akong masyadong time ngayon kaya these ceramic spray sealants ok talaga for me. Even ung mga ni-follow ko sa YT, puro coatings and spray sealants na ang gamit. Sa polishing and compounds na lang nagkakatalo.
November 17th, 2019 01:22 PM #7292
Guys, ano marerecommend nyong pressurized water washer na pwede kabitan ng foam wash spray tool?
November 17th, 2019 01:59 PM #7293
agree bro, bottomline ay sa paint prep. excited ako sa parating na TW items ko. i like to try din yung mtx crystal fx.most if not all of pressurize washer ay may nozzle fitment/adapter na pwede kabitan ng foamer. yung iba may kasama din na foamer. kung meron ka ibang foamer, you can bring it in the store para you can get the right adapter. for the foaming, better get a washer with a bit higher pressure as the entry level ones may not have the right pressure to create a nice, thick foam.
btw, i have the nilfisk 130.1, its more than 5yrs now and still okay. may kasama na din foamer nung nabili ko. i seldom use the foamer na since naubos na yung cg super suds shampoo na gamit ko. i tried using yung microtex shampoo pero manipis ang foam na nagagawa ko kahit damihan ko shampoo.
November 17th, 2019 02:18 PM #7294
November 17th, 2019 02:25 PM #7295
November 17th, 2019 02:52 PM #7296
November 17th, 2019 03:00 PM #7297
i see. i have not try pa other foamers kasi except sa stock. anyway, i seldom use a pressure washer. kapag lang mag polish ako and need mag-decontaminate saka ko ginagamit. for weekend washings, enough na sa akin pressure ng garden hose[emoji4]
November 17th, 2019 05:45 PM #7298
Correct. Actually iniisip ko nga na pag pressure washer dapat mas tipid sa tubig. Thats not the case for me. Or malakas lang talaga ako gumamit ng water. Haha
Malayo performance ng stock foamer sa foam cannon. Try searching, foam it philippines sa fb. I think they sell those.
November 17th, 2019 06:51 PM #7299
i think matipid naman sa tubig yung pressure washer talaga. you can compare yung tubig na nasa ground using pressure washer saka kapag gamit ay hose sa linya ng tubig. convenient lang tingnan gumamit ng pressure washet pero hassle at time consuming lang din mag set-up pa, koneksiyon sa tubig, sa kuryente, palit2x mga nozzles, timpla ng shampoo, hila dito, hila dun[emoji29] eh yung garden hose, konekta mo lang hugas time na. basta maayos lang nozzle, ok na din. sometimes nga pwede na "finger" nozzle lang[emoji16] pwede mo lakasan o hinaan presyur, o walang leave it open dulo ng hose para sheeting effect[emoji6]
November 17th, 2019 09:02 PM #7300
I also apply Beadmaker on plastic trims and even on the windshields and glass. It makes the glass hydrophobic and dustphobic, makes it easy to wipe off the dust after a day's trip!
I wonder if there's an official local distributor of P&S products. I need to stock up some supplies hehe
Confirmed: The Hyundai Creta N Line will make its PH debut later this month | TopGear PH...
2022 Hyundai Creta
