Results 1 to 6 of 6
August 28th, 2012 03:34 PM #1
Hello. Our i10 recently suffered a deep, ~1 foot scratch on its right rear quarter panel.
Question: Is there such a thing as "spot repaint"? Meaning, only a specific area of the panel will be repainted.
I'm asking because the said panel starts from the rear of the car up to the front bumper area, and after visualizing the work needed, I am quite certain that the rest of the car will be "abused".
Thanks.
August 28th, 2012 05:17 PM #2
it depends on your negotiation skills with the painter.
but most shops paint on a per panel basis.
August 28th, 2012 06:46 PM #3
This is what I mean.
The damaged part is the boxed area. However, if we go by "per panel", you will see that it will not be a simple undertaking simply by looking at the size (red lines) of the panel. My question is, is it possible to repaint just the damaged area? I do not mind paying for the whole panel provided the work is exemplary.
- Mar 2011
- 70
August 29th, 2012 08:40 AM #4well see if the paint less dent repair can solve your problem. I am a fan of frankline as they say so I will recommend
to you his shop at 31 examiner st. in West triangle in Q.C. bring it early as there are many clients in the morning
August 29th, 2012 09:38 AM #5
I have been a customer of Frank before, and unfortunately this is something outside his services since the scratch is too deep and the primer has been stripped.
- Jan 2010
- 126
August 29th, 2012 03:57 PM #6
high idle RPM at engine start
