Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
    Aug 2006
    #21
    There actually isn't a general idea of product/item when it comes to removing swirls. It depends on the swirls themselves and technique. Yellow pad and Megs cleaner polish/medium cut will actually make the swirls worse on a car with already light to moderate swirls...
    There's no way a PC with yellow pad can seriously damage your clear coat at all no matter how thin it is...
    Sep 2006
    #22
    Quote Originally Posted by blink21me View Post
    I was talking about the DACP #83 not the cleaner.Like you said it depends on the technique.
    Can i try PC on speed 6+yellow pad+ 3m rubbing compound on your car?Do not under estimate the pc.
    Aug 2006
    #23
    I personally haven't tried # 83 myself, but it's supposed to be less agressive than the PB SSR3, and just a little more agressive than the 2.5... Based on my experience, SSR3 on yellow pad will not damage the paint unless you put it on one spot for an hour or so, that would be the only way it will generate enough heat to polish through the clearcoat...
recommend a good orbital buffer
