Results 1 to 9 of 9
    May technique ba kayo? Ang hirap eh, medyo sticky during the first wipe. What I normally do is fold the microfibre and hold it like a pad then I use a separat MF for buffing. By doing this however, I don't maximize the MF towel.
    May iba pa ba kayong techniques?
    Isa pa pala question ko, I read somewhere that you can apply the QD right after rinsing your car before dring. Kumbaga isasabay na sa pagtuyo para isang punasan nalang.
    Is this okay?
    what i do is to wash the car, dry it, and apply the QD.
    for applying, i just spray a thin volume, and dry it using MF.
    May pagkamalagkit kasi yung QD. Medyo mahirap i apply. Light pressure ba or pressure as if you apply a cleaner wax?
    Quote Originally Posted by Djerms View Post
    ano gamit mong QD? gamit ko kasi Turtle. Hindi sya ganung kalagkit.
    i'm using light pressure lang. Pero gamitin mo na MF is dapat malinis ha? Yung hindi mo ginamit anywhere in drying.
    Apr 2008
    ako gamit ko MOM'S spray wax...spray and wipe it off with another microfiber towel..o kaya spray then use the other side to wipe it off.
    meron ako nabasang thread wherein yung carlack68 long life sealant eh pwedeng gawin QD..mukhang ok nga kasi mas tipid tapos considering yung carlack68 long life eh for protection and shine..
    sana may makapag share kung paano yung mixture(sukat) nito with water..
    Aug 2006
    I have stopped using QD, malagkit kasi lalo na pag naarawan, kumakapit ang mga maliliit na buhangin kaya gumagaspang ang body.
    Nov 2007
    With regard to technique, this might help:
    http://www.autopia.org/forum/guide-d...detailing.html
    Dec 2003
    what i usually do to remove QD.
    is to wipe it dry with MF and spray some Last touch (meguiars) or showtime (mothers)
    so that it wouldn't be hard to remove.
    Jul 2006
    That's weird, I never had problems with quick detailing products. I use Meguiars though, it's still pretty full as I don't use it much, but when I do it's not that sticky. Maybe the paint is still dirty? Have you tried claying it first?
QD application technique
