Results 411 to 420 of 433
April 14th, 2021 05:32 PM #411
Has anyone tried this?
Touchless Car Wash With Foam Cannon - Does it work? - YouTube
Touchless carwash. Just realized kumpleto naman pala ako sa gamit para dito. Wondering if this really minimizes swirl marks.
April 15th, 2021 08:43 AM #412
- Dec 2008
- 85
April 29th, 2021 03:08 PM #413
- Jan 2007
- 2,234
April 30th, 2021 09:40 AM #414For touchless wash I feel like the car needs to be quite clean to start.
Maybe if's just dusty from sitting during quarantine.
If you've been driving around in the rain I think you really need to agitate to get rid of sticky dirt and grime.
- Jan 2009
- 121
May 27th, 2021 04:52 PM #415I bought greenfield brand pressure washer, foam lance bottle, fixed spray tip to protect paint from over pressure, and pivoting attachment so I can adjust the angle of spray upward or downward. All from Lazada. I am satisfied of the performance. Just enough pressure and I can do foam washing and just rinse para iwas swirl marks. Rivers brand of detailing products is okay and not too expensive.
- Feb 2014
- 2,536
August 26th, 2021 12:19 PM #417
Ask ko lang about PW accessories. If naka quick connectors (QC) na sa gun/wand, do I still need a swivel connector? Or will the QC already swivel to prevent kinks sa hose?
Sent from my Nokia 8.3 5G using Tapatalk
August 27th, 2021 10:34 AM #418
- Feb 2014
- 2,536
May 27th, 2022 04:56 PM #419
just ordered Mace Plus washer on lazada. P1500 only. seems to be a cheap version of the worx hydroshot. check out the bulge at the piston mechanism. same shape. probably the same internals
- Feb 2014
- 2,536
May 31st, 2022 04:24 PM #420
just got the Mace Plus. just as i suspected, same "engine block" as the worx hydroshot, but cost optimized
this thing has the quality level of a branded tool for just P1500. i think it's a steal.
if there's one negative it's the battery, a small 2Ah so runtime is limited, and the cells are cheap chinese no-name cells
high idle RPM at engine start
