Page 25 of 44 FirstFirst ... 1521222324252627282935 ... LastLast
Results 241 to 250 of 434
    #241
    If you can confirm the type of pump, then that answers your question. Again from what I know, centrifugal pump is not self priming while reciprocating pumps are self priming.
    Ok, I'll take note of this.. Salamat! [emoji1]
    #242
    Usually ilang dapat psi ng gripo? But i think our pressure is enough since umaabot naman sa overhead tank yun Maynilad.
    residential potable water supply pressure usually around 40 psig
    Feb 2014
    #243
    piston yan. see the 3 cylinders at the bottom?. afaik you can't generate high pressure w/ centrifugal
    Dec 2017
    #244
    Quote Originally Posted by Vodka View Post
    I didn't check the picture earlier... and yes, I couldn't see the usual "volute casing" so this doesn't qualify as a centrifugal pump.
    For high pressure application, centrifugal pumps can be arranged so that it is "staged". An example is the feedwater pump used in a boiler. A three-stage centrifugal pump might be an overkill for ordinary industrial application. Well, I might be wrong as I don't have much knowledge about this.
    #245
    Meron na ba nakabili nun binebenta na pressure washer na kawasaki brand binebenta sa shoppee and Lazada?
    Parang isa lang gumawa ng mga binebenta na Black and decker sa mga ace pero half the price.
    Jan 2017
    #246
    I have an hp-w302. .. been using it for more than a year na.. . regularly every sundays. . siguro mga half day. . . first to clean the car after which panglinis ng kulungan ng baboy. holding up naman. i just spray silicone oil dun sa mga rubber o-rings oara d tumigas.
    #247
    Quote Originally Posted by mcoy123 View Post
    Yan ba yun Meron gulong or yun maliit? Order ako bukas. Pwede diretso gamit na matagal hinde umiikot yun motor? I mean I like 1-2 hours Pero hinde naman siyempre tuloy tuloy.
    Jan 2017
    #248
    Yun me gulong sir. .. i use it for around 3hrs or more pa nga sir.. pero d tuloy -tuloy =)
    Basta make sure na yun supply ng water eh available. . ..pag naubusan eh iinit yun motor and it would lead to premature wear.
    Malakas naman yun focused na spray nya. . . Yun lang fine(?) na spray nyaeh sana mas madami pa ang lumalabas na water para mas mabilis ang rinsing
    Sent from my SM-A720F using Tapatalk
    Oct 2009
    #249
    RE: Bosch power washer AQT 33-11
    FYI
    After 1 year of use, the aluminum casing that housed the piston developed a crack. the thickness of the aluminum is thin. Bosch service center did not have the parts.
    Am now looking for an alternative brand
    Dec 2017
    #250
    Quote Originally Posted by tanigui View Post
    FYI
    I think this kind of appliance is of disposable type.
pressure washer brands
