Results 11 to 14 of 14
May 3rd, 2007 10:47 PM #11
pearlescent colors should NOT fade if done properly with the correct base + clear process. even non-OEM finishes can last a very long time if done properly.
basically, the only difference between solid, metallic and pearlescent finish is the materials used in the basecoat:
solids = pigment only
metallic = pigment + metal flakes
pearls = pigment + mineral flakes, usually mica
i've personally painted parts with pearl colors that have not faded. no experience with "candy" colors, but have personally seen some really cheap looking jobs (maybe a single stage, like theveed mentioned) that look like they never had any decent luster to begin with...so maybe that's where this perception started.
i have no idea why somebody would do a single stage pearl in this day and age....but as long as you have a good painter that performs a two stage or base + clear paint process you should have a shiny and durable finish for years
May 5th, 2007 10:49 PM #12
^salamat bos. it's a bit too technical for me but i do get the gist of your post (same goes w/ bro niky's and bro theveed's post). thanks for the heads-up mga bos at least di na ko completely ignorante pag dating sa mga kailangan i-clarify ko uli sa shop
BANNED BANNED BANNED
- 3,790
May 6th, 2007 07:09 AM #13try mo "house of kolors" na paint kilala ito sa US and have a phil seller (found in the seller of meguires sa kamuning extension).
AFIK their paint and technology will not fade easily.
- Mar 2005
- 125
Xiaomi E-Car
