Results 21 to 30 of 30
November 25th, 2005 11:47 PM #22Originally Posted by ILuvDetailing
Originally Posted by ineedmorehp
November 26th, 2005 01:25 AM #23
GM Autoworld Shaw - the only Honda being repaired inside their garage.
November 26th, 2005 02:11 AM #24Originally Posted by ineedmorehp
November 26th, 2005 06:15 AM #25
ineedmorehp:
How much are they charging you?
How long will it take for them to finish it?
How will they match the color? Is it computerized? If not it will be hard to match the color...
What prep material are they gonna use?
Problem with not repainting other panels is that the color will most probobly not match especially if its not computerized because there is fading in the old paint unless maintained properly.... Pag mano mano yung color matching I suggest you find another painter... IMO
November 26th, 2005 08:03 AM #26Originally Posted by russpogi
Btw, ganda pala ng bagong kulay ng Aveo nila, parang same color ng sakin pero mas vissible yung silver effect. (Kumukutikutitap. Perong hindi batik-batik na parang sabon panlaba ah. Hehe)
Another question, nakakita ako ng pink changing to green (vice versa) color gradient on Honda ESi. Ganda! Panu yun?!
OT: Bro, uu nga pala ang linis ng marikina. Sobra.
Tsikot Member Rank 3
- Oct 2003
- 699
November 26th, 2005 07:35 PM #27Originally Posted by ineedmorehp
(sorry that's the best help i can give you. problema din dati ng civic ko yan. kaya lang ibinenta ko na ang civic tapos ko ipagawa sa kanila.)
November 27th, 2005 12:48 AM #28Originally Posted by ILuvDetailing
but it's also not a good idea to rely 100% on computer matches because in my experience they can also come out wrong. the painter has to also know how to manually adjust the paint to color match perfectly.
i also agree that it is easier to blend out to adjacent panels (however, too often painters will use this as a crutch to substitute for not perfectly color-matching the paint, bad bad bad)...this doesn't require too much extra effort because all they're doing is spraying the basecoat lightly on the other panel, and clearcoating everything.
i hate doing this - i preferred to try to get the color matched as perfectly as possible and spray as small an area as i could...otherwise you end up repainting half the car for a simple door repair
November 27th, 2005 03:08 AM #29
ops medyo ot...hehe
mga masters saan kayo nakakabili ng 2K~4k na pang wetsand..salamat
November 27th, 2005 10:48 PM #30
Thanks sa mga reply nyo. Post ko pic before and after... pag nakuha ko na oto...
Ayos sumabay pa sa Greenbelt 1.
Makati CBD parking
